it is a summit cam. here are the specs
Summit Racing Part Number SUM-3600
Cam Style Hydraulic flat tappet
Basic Operating RPM Range 1,200-4,800
Intake Duration at 050 inch Lift 204
Exhaust Duration at 050 inch Lift 214
Duration at 050 inch Lift 204 int./214 exh.
Advertised Intake Duration 262
Advertised Exhaust Duration 272
Advertised Duration 262 int./272 exh.
Intake Valve Lift with Factory Rocker Arm Ratio 0.448 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio 0.472 in.
Valve Lift with Factory Rocker Arm Ratio 0.448 int./0.472 exh.
Lobe Separation (degrees) 112
Computer-Controlled Compatible No
Valve Springs Required Yes
Camshaft Manufacturers Description Smooth idle, excellent low-end torque/horsepower, towing, good fuel economy in stock engines. Good camshaft for turbocharging
Unfortunately, it was installed 2 degrees retarded. only the timing cover and water pump were installed, so, redoing it would not be THAT much of a hassle.
Is it worth it to crack it open and reset it to straight up or advanced?
The gentleman who helped me builds old school hemi race engines. An old timer and wealth of knowledge when it comes to his specialty, so I went with his suggestion. But, it appears I should have consulted the bronco experts first.
So, rip it open or leave it for now?
He also suggested the valvoline 20 /50 racing oil with the zinc and phosphoruous additives. Has not been put in yet, waiting on the oil pan. Is there any other suggestions that may be better?
Mike
