New Wheels and Tires
Desert Rider
Albuquerque
After months of contemplating, I finally decided to splurge on new wheels and tires.
Background: A couple of years ago I replaced my stock bronco gearing with 4.10s, added a 3.5” WH suspension lift, and installed 33” X 9.5” X 15” BFGs ATs (pizza cutters) on the stock wheels. In general, this tire/gearing setup has worked great. BTW, my front fenders are uncut and rear fenders are cut. I have plenty of wheel well clearance with this setup. Now, a pic of my original setup with 33 tires and stock wheels.
What I’ve realized with this gearing/tire size is that it works well around town (slower speeds) and during four wheeling. It also gives my bronco a refreshed source of energy with the lower gears. However, while driving on the interstate highway my bronco tops out in speed at 60-65 mph at fairly high revs. In addition, my C4 tranny shifts rather quickly (1st to 2nd) while driving through an intersection and then again from 2nd to 3rd… a consequence of lower gearing.
This is why I decided to purchase new (taller) tires and reluctantly, new wheels. The reasons I replaced my stock (6.5” X 15”) wheels are: 1) they are too thin to support tires wider than 10”; 2) there aren’t many choices (manufactures) of tall skinny tires (< 10.5”); 3) tires taller than 33” only come in wider sizes (<11.5”); 4) there is one manufacture of tall/skinny heavy duty off road tires (Interco 34” X 9.5” X 15”) but these are costly, noisy, ruff on the highway, and wear out fast. There also is the potential problem of using wider 15” wheels and taller/wider tires, including issues with steering linkage hitting wheels or tires, wheel weights rubbing linkages, wheel spacers required, etc.).
I wanted to buy wheels that would keep my bronco looking somewhat vintage and classic. I purchased 17” wheels since there are many other tires available in this size. I did find out, however, that larger wheels equate to more expensive wheels and tires. One thing I found is that there limited 17” wheels available that fit the bronco bolt pattern and are available with 3.5” backspacing unless you custom order, have made (steel wheels), or something else beyond my budget or experience. The setup I purchased are 17” X 9” US Mags Indy’s (3.5” backspace) mounted to 34” X 10.5” X 17” BFG ATs. This tire size is a new size for BFG in their new generation AT. I shopped around, and the best price I found was at Discount Tire, $2550 plus a $100 rebate, so $2450 installed with caps (includes 5 wheels and tires). The good thing with Discount Tire is that you can get tire rotation, balancing and flats fixed for free in any larger town.
After install, I noticed better speed range on the interstate, and the ability to drive at slightly higher speeds. The overall ride seems to be a slightly softer and more comfortable; however, the steering is slightly more obvious (harder).
I did have some wheel well clearance issues. I had a slight rub on the driver’s side front fender, so I trimmed the very front and lower part of this fender; I also trimmed the inner sheet metal at the rear side of this fender. I did the same trimming to the passenger side front fender. I also had to trim the rear fiberglass fender flares (using tin snips and a dermal tool), in the lower front edges. Hopefully, I will not have to install a 1” body lift!
I plan to take the bronco to the Moab Bronco Safari in May for some real field testing!
Crush
Greenbottom, WV
If it were me i woukd have moves the rear adel back 1" to 1.5" using ez-inch or sero rates to center the wheel in the wheel well. This woukd make it look more centered and kept tou from trimming the flares
Whoaa
The new tires and wheels look great! I really like the look and stance of the retro slots in 17" diameter.
Not all flares are installed the same. Big tires with less clearance magnifies the problem.
The rear flares on this Bronco appear to have been installed "center" between the gas caps, but not center to the fender itself or the fender opening. They appears to be the old-style rigid fiberglass flares -I have the same style on one of my Bronco's. And it looks like the flares are installed in such a manor to slightly tip them back.
You can fairly easily cut the outer sheet metal all the way forward to the little bracket that hold the sheet metal. Installing some new-style flexible flares would go a long way to center things up.
And as already mentioned, a little more work but still not a big job is moving the rear diff housing back and inch or so by using an off-set leaf spring perch.
The 1" body lift that WH offers is a sweet setup that doesn't create the telltale gap generally associated with body lifts, but has all of the advantages of a little more working room, plus of course it squares up the body and gets rid of the old rubber mounts.
Here is a 77' model with the fuel doors in the way, also running the old style fiberglass rigid flares. Notice the rear flare is very slightly tipped "forward" to try to gain room at the front of the tire, plus the flare is crowded as far forward as posible towards the forward fuel door
And the rear end housing is moved back about 1 1/2" by using an off-set leaf spring perch
Viperwolf1
electron whisperer
Looks great Ed. I was considering the 34's but may size down a little since you had some rubbing issues on the front. With my backspace the rears should tuck in nicely. I did move the rear axle 1" back.
67RT
I wish I were closer as I want your old wheels and tires!. Nice truck!
gnsteam
Lincoln NE
Great choice in wheels and tires. I have been a long time admirer of your Bronco with the stock look tires set up. But now I like it even more.:cool::cool:
I have a similar 76 and I purchased the 17 x 9 Indy Slots. I'm still in the process of saving up cash for the Wild Horses 2.5 suspension lift and tires.
Thanks to your post I now have another tire option to check out. I was leaning towards buying Goodyear Dura Tracs in either LT315 or 285/70R 17's. The 315's are 34.4" x 12.7" and the 285's are 33" x 11.5". I like the idea of the larger diameter 315's but not the 12.7" width. I think I would be happier with a 10.5" width tire bases on my driving habits of 95% pavement.
Thank for your post and your Bronco looks great!!!:cool::cool:
