73stallion
never mind, my mind was on something else.
?I would never cut a 1st year roadster... that is a vehicle that you restore to stock.
If you are even thinking about cutting, that shows you are looking to do a lot to a vehicle. You should start with an already cut 302 Bronco and go from there. I bet you would be happier in the end and someone looking for an uncut would be very happy with yours.
I think my uncut with a 2" lift and 30's looks classic. But the cut Broncos with lifts and big tires look TUFF. Anyone interested in a clean uncut 1972 200ci
ESPEEDY said:I am the proud new owner of a un cut 66 roaster, and thought the cut rear fenders was a factory option. I am planning a lift kit only cuz it looks good, however the bronco is not going to see any heavy off roading and I would like to put some reasonable tires and wheels on it and not cut the fenders. I would like to put some 31's. Should i use a 21/2 or31/2 lift kit. She has a 200 6 cylinder(she's a cruzer not a bruzer) in and I have ordered a new floor shift from the grave yard. Any info would help and sorry for the such a stupid question. Thank you in advance
Remember, pedal to the metal untill you see GOD, then back it off just a bit! ;D
A lot of the replies above are in regards to the original question regarding cutting the quarters on an original 1966 Roadster (Factory soft top) which is a rare find. There are many of us that would restore one to original condition even if it means replacing most of the sheetmetal. From what I can tell yours is not an original roadster so the answer will be different. Many of us would still prefer to see it left alone since uncut EB's are becoming rare. There simply isn't any reasonable way though to put 40" tires under an uncut EB though and that is all there is to it. Doing so would make it dangerous either way you do it. One way would be to try to tuck them up under the wheel wells which would make it unstable because it would be too narrow. The other is to put perhaps 15" of lift on it which would also make it unstable. If you cut it then you "might" be able to get by with just a 5 1/2" suspension lift. Most of them you will find though with 40" tires under them will have the quarters and fenders cut clear up to the bodyline "and" will have at least 5 1/2" of suspension lift plus a 3" body lift. Even with all of this you need to cut the rear tubs and rework them to keep the tires from hitting if you have a decent amount of flex. Even with my 37" tires and all of these (Extreme cutouts and 8 1/2" of lift) I still need to cut the rear tubs and extend them to stop them from hitting when they flex which I'll be doing within the next month or two.CallmeGoof said:Thank you guys for giving me your opinions. D-cannon thanks for giving me both sides of the fence anwsers. I am planning on doing a lot to and with my Bronco so that is why I was wondering about cutting it. Believe me nobody would want my "flintstone mobile" as it is rusted out pretty good. Some cutting is necessary for the restoration as it is. I was originally planning on cutting my fenders until I read this. Now I guess I have a decision to make.
THANK YOU ALL FOR THE INPUT!
Jen
Jen
