Newbie C4 questions
brianca
I just picked up a '77 with a 351w and a C4 auto in it. Most of the time it behaves exactly the way I would think, but there are two things it does that I was wondering if they are normal.
1) When I first put it in D after it's been sitting, it sometimes refuses to engage. If I put it in 1 and manually shift up to D all is well. There's always a few seconds of lag between putting it in D and it engaging, but sometime it seems like it'll never get there unless I manually shift.
2) When shifting from 2nd to 3rd, it downshifts for a second and builds up rpms before the shift. Sometimes it gets stuck in that down shift and won't complete the shift to 3rd unless I let off the gas entirely and reapply. This happens at around 1/4 throttle when it happens and no matter how high I take the rpms, it won't shift. Other times it shifts quickly.
Are these normal with the C4? If not, what do I need to look at to make them better. If so, is there anything I can do to improve them?
brianca
broncolove
The Bronco Ranch
S.E. Michigan
Try a new shift modulator. Or make sure yours has a Vacumm line attached to it. Its located on the bottom passenger side of the trans near the pan. Also do you have kick down linkage on it? Could also just be blow by in the Valve body. But try the Modulator first, Cheap and easy, and a common problem
B
brianca
I checked the oil level and it is fine. I also checked the hose on the modulator, but I didn't replace it. I was thinking of getting one of the adjustable ones that I've read about on here.
Maybe I'll swing by and pick one up on the way home tomorrow and give it a shot.
brianca.
It sounds to me like you have a linkage problem. Check and adjust the shifter rod. Also check the kick down rod. it sounds like it is adjusted to come in too soon or there is not an external return spring. There are adjustable vacuum modulators you can use to help with shift timing.
jerry74explorer
Baton Rouge, LA
Hate to tell you this but my c4 acted just like that right before i lost it. The day it went, it got worse and worse till I lost all of the foward gears. If the modulator doesn't fix it you may have to check to see if you have a burned clutch pack or band.
Mal
My 77 acted similar.The kick down was just binding up,tweeked
it a bit and all is well.hope thats all it is.
B
brianca
I bought a new vacuum modulator that will go on this weekend. If I remember correctly, it appears that I do not have a kickdown running from the carb to the C4. I have the lever on the C4, but nothing connected.
If you do not hook up the down shift then you must tie it up. I use a spring hooked to it and hooked it to the end of the exhaust manifold. The internal spring on this lever is not strong enough to hold this lever steady if it is moving around ever so slightly it can cause your erratic shifting.
B
brianca
Ok. I replaced the modulator and put in a filter kit while swapping out the fluid.
The new behavior is that 'D' seems to be stuck in third gear. If I manually shift up to D it works great and shifts into third as expected, but if I leave it in D at a red light, it pulls out as if it never downshifted.
Ideas?
Also, does anyone make a C4 pan with a drain plug? What a freaking mess. ;)
B
brianca
No one? I can't imagine that it's just an adjustment on the modulator for this one. I was wondering if maybe the little activator rod that sits in the modulator could have been misplaced. Is it possible for it to be sitting in the modulator and not in the correct position inside of the C4?
B
brianca
Anyone have any advice on this before I head home this afternoon and start poking around again?
BwoncoHowie
C-4 Wizard
Sounds like you have stuck governor valve, or stuck shift valves. If you need to drive it, manually upshift it till you get a chance to to find out what is causing the sticky valves. Dont wait too long though because sticky valves are most often caused by ferrous particles, which means you could have a hard part going bad inside the trans.
If you have a missing modulator pin it will cause the trans to do some pretty wacky things, but i've never seen this cause a "stuck in 3rd" condition.
~BH
BwoncoHowie
C-4 Wizard
The best way to install the modulator is to put the spool valve in the trans and put the pin in the modulator before installing it. The pin will be guided into the back of the valve as you install the modulator. If it goes in wrong, you will never get the modulator all the way in. Hence, if the modulator and pin assembly goes in all the way, its installed properly.
~BH
B
brianca
Thanks. I got home tonight and decided to drive it around the block a few times and see what it was doing, and it seems to be a little different once again.
Current behavior:
1) Reverse is great. If I could just drive backwards everywhere, I'd be fine.
2) 1st engages, but moves very slowly even for first gear. Doesn't seem to be engaging well. No noise though.
2) 2nd seems to be a little better than first, but again the truck is barely moving. Again no odd noises, it just seems to be in some sort of odd granny gear.
3) 'D' no forward motion. The tranny is engaged because I can let off of the brake and the truck will not roll backwards on on incline, but it will also not pull forward at all.
It doesn't sound good. I talked to a mustang buddy today and he said that often the trannys are really warn and the old oil in them is making up for the wear and once you put new oil in them they start acting up.
Where to from here?
mtnbound
N Idaho
My c4 did somethings similar and I droped the fluid into a clean pan so you can look at it, if the fluid does not look clean then I would say it is time for a rebuild, if it is clean pull off the governor and check the valves, they shoud move very easy, but sometimes they stick. If you want to before you drop the fluid drive it reverse for as fast as you can safely for a 1/4 mile or longer. The reason is because the c4 builds more pressure in reverse and it pushs the fluid in reverse thru the tranny possilby flushing particles out of the governor. A extreme method is to put it into drive and go just a couple miles an hour and then slam it into park it can unstick the valves but it scares me to do that.
Jazona
Prescott Valley, AZ
While we're on C4s, I have a fluid level question. When I check fluid level, trans hot, flat driveway, I get drastically different readings at different times, i.e., one saying add one day and then another day it's 2 inches above the fill level!!!
On cool mornings, the torque conv. starves for a sec and then engages at slightly higher rpms (which I'm told isn't good for it). Is the torque conv. draining back excessively or ???
thanks.
B
brianca
Ok. I tried the above tonight. I drove a while in reverse and it was fine. I put it back in gear and could barely get it up to 10 miles an hour. I let it roll down to barely moving forward and dropped it in park. After that I have no forward gears at all. I ended up driving home backwards and it's sitting in the drive now with no forward gears working at all.
brianca.
BwoncoHowie
C-4 Wizard
Pull the pan and post pictures of whats in there. Sounds like your forward clutches went out, which is why all your valves are sticking.
I don't recommend Park slams on sticking governors. It's to hard on the park mechanism and doesn't go after the root cause of the problem it only treats the symptom.
~BH
