Newbie - Lots to Learn!
KingR
New to the forum and it's already been a big help! Thanks to those who chimed in on my thread asking for some help in the Santa Rosa area. I ended up buying the Bronco, so now the fun begins. Thought I'd post some pics and a few things I'm working on- since I didn't actually get to work on them today! I already feel more productive. %)
It's not in bad shape and drives pretty nicely. Has a 351W hooked up to a 4r70w transmission with an old Baumannator. Dana 44 front end with disc brakes and Ford 9 rear with rebuilt drums. 4.5" lift with Bilstein shocks currently on 35" Duratrac tires.
What I'm working on/thinking about now:
- I'm thinking about dropping it 1" and putting some smaller A/T tires on it for improved road cruising use. It's not going to see a lot of off road (especially in the near future), though I'd like to have the option to do a bit if I get the chance.
It also currently has no front drive shaft, as the old one (which I have) didn't measure up after the lift. I'll need a new one but best to wait until I've lowered the vehicle to measure this back up.
- Horn doesn't work and blinkers/hazards work intermittently, not at all, or show solid. Found out there are LED bulbs installed with original flasher units, so getting LED compatible units. I'll be taking the steering wheel apart to check the horn and blinker/hazard switch. May have to replace with the switch from Tom's.
- Remove and inspect, then replace and/or tighten top bolt on track bar. There was a little movement when moving the wheels side to side.
I've not spent a lot of time working on vehicles before, but this is my second Bronco. I had a '95 FSB about 10 years ago, and have been wanting another ever since. Looking forward to learning!
bronconut73
Great eb.
Be sure front and rear gears match before putting in a new drive shaft unless you have already confirmed that.
Also sometimes the top bolt hole for the Trac-bar bracket will wallow out. Simple fix is to weld really thick hardened washers on each side and use a longer grade 8 bolt.
This is a great site.
You have come to the right place,
Welcome to CB
Greetings and Salutations.
SteveL
Huge chevy guy
Hawthorne ca
Nice bronco. You might be able to find replacement switches at a local napa. If the track bar has play get a set of bushings before you pull it apart. Bolts should be fine unless bushing is gone.
You know, we didn't even touch on the rear wheel bearing "thing" that all new Bronco owners should know about.
Any chance you know the history of the rear end? I think you said it had been worked on, and the brakes were new?
If so, perhaps the rear wheel bearings are already new. But if not, best to keep that on the front burner of things to check out.
They generally have about a 100k life expectancy, or about 30 years. Since it's not coming up on 45 years (in a year or two) it's worth looking into.
The fact that it runs and drives so well, doesn't have many funny noises, or act squirrely (much) is a good sign. But still worth checking.
Mine did not give any symptoms while driving, but when I inspected them I found they were both toast at about 90k miles or so.
Great Bronco. Maybe get some good shots over by the GG Bridge, or the Marina or some other SF location and get a shot in the calendar. Submissions are being accepted right now. Most of the best shots are off-road of course, or sitting by some old school roadside Route 66 kind of spot. But I can see some good shots coming from your area too.
Hmm, maybe I should park in front of the Apple Spaceship and take a selfie!%)
I know... Drive it down to the docks while the fleet is in town! Should be some good action shots available, what with the Blue Angels passing by in a blur.;D
K
KingR
Great eb.
Be sure front and rear gears match before putting in a new drive shaft unless you have already confirmed that...
I haven't confirmed. Thanks for the heads up- I'll look into it.
Thank you- found some old posts on replacing the bushing and I'll keep it in mind!
Any chance you know the history of the rear end? I think you said it had been worked on, and the brakes were new?...
PO said the rear brakes had been redone, but don't know much else about the rear end. Definitely need to check those bearings. Maybe we can chat a bit more about it at the WH meet?!
Welcome to the madness--love that color
Thanks! Originally thought I'd paint it pretty quickly- then I watched the dog throw her paws up over the side of the truck grinning to greet me and a new paint job moved to lower priority. Pics probably make it look a little better, though...
Welcome.
Now the Fun begins...
Indeed- hope to see you around! I like it over there on that side of Santa Clara Valley!
RPM289
Welcome to the fun!!!!! Great folks on here to help out on a already great looking rig!
langester
MASTER OF MADNESS
Welcome! Looks like you got a good solid Bronco as well! Congrats on the new purchase.
