First post here.
Already looking for help ;D
I have been looking for a jeep, sami, or something similiar for off-roading. Well, I found a bronco and have no idea what it may be worth. Any, ANY help is appreciated.
It is a '67 sitting under a carport. I looked at the frame and all around the body. NO RUST! Paint is fair at best, evenly faded/dull and some chips. Body is straight. It did not have any top on it when I saw it, but he says he has a new soft top for it. Engine is 351W bored .030 w/ mild cam. Tranny is 4 spd. manual in floor (could have been 3 spd.- not sure) Transfer case, tranny, and engine all fresh rebuild with less than 4k miles! Electronic ignition, (if I remember correctly, it has a 2 barrel carb.), power steering, power brakes, disc brake conversion. Rear tube bumper (smittybuilt?), and front aftermarket bar (not sure what it is called, but it's the one sloped up about 45 degrees in the center-sticking out a foot or so) and new warn winch. not sure what size winch, but he says it has only been used once, that was just to let the cable out, and reroll it! Tires are worn 33's I believe. Does not appear to be lifted. Truck is sitting on concrete, there is NO oil anywhere under it. Runs great, have not had a chance to go back and drive yet. Appears to just need some TLC. What do you guys think.. any rough ideas? ?:?
Thanks in advance
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks in advance
