Newbie needing help
Airtime
hi, hopefully someone here can help me I don't know anything about broncos but my uncle past away and he had an old truck that nobody wanted.My aunt told me I could have it so I drove 4hrs to Virginia to pick it up and she told me it was a 1965 bronco it is all stock with a half cab on it. the truck is in rough shape but is complete and not hacked up with a 6 cylinder engine.The title is listed as 1965 ford bronco but i can only find info on 1966 or newer don't know if it's a misprint or not. I'm not sure if I have anything of value here or not the truck needs a radiator. I did start it up and let it run for a few seconds then shut it down. if any body could give me any info it would be appreciated Thanks
jonpblewis@yaho
San Diego, CA
Maybe this will help
lowbush
Summerland Key, FL
Does the vin have a U13 in it, there where some 66 Bronco's titled as 65's so it may be a early production 66. It could also be a swapped title on a later production year Bronco the vin number will tell you a good deal about what you have. Some of the guys on here can tell you everything you need to know by the vin.
A
Airtime
I've learned something already it looks like it's the Pick up version. thank you 69 dude
A
Airtime
The vin# starts with a u14 I do not see a month on the title just a year of 1965
76 One ton
Shawnee, Ok
Welcome to CB. Sorry for your loss. Your Uncle must have been a pretty cool guy to have an early bronco. Show some pics of your rig when you get a chance, take a pic or write down the vin found on the glovebox door and these guys can tell you more about it. If you plan on keeping it become a contributor for $12 a year and it is easy to post pics. Otherwise you will have to post a link to another host site that you upload pics to.
A
Airtime
I will try to get some photos posted in the next couple days.I believe a restoration would be beyond my skills so I think I'll probably end up selling it. I don't want to give it away so that's one of the resins I joined to get a little info on it. I couldn't find much info on the web so all your info has helped a bunch already thank you
half cab
Guru Bronco
Now if you had a '65 2 wheel drive you would really have something ;)
half cab
Guru Bronco
Them yrs the vin will be on the dr. side kick panel.
