Newport Engineering Bronco Wiper Setup Review
broncoitis
Ok, I won this setup at the roundup in Pa this past year. At the time I was honestly pretty excited that I won the Newport Kit. I have read up on there stuff and it all seems to be top notch.
So today I decided to finally install this in my truck! Some events are coming up and I would possibly like to attend a couple of them. So before I took off the old assembly I measured the width between the current wipers arms on the windshield frame and came up with a measurement of 19.75 inches give or take! Low and behold the spacing on the Newport Kit was over 21 inches. They won't fit! No worries, there are other mounting options that will match up with the 19.75 inches already cutout on the case. All I have to do is move them and all is good. Nope! Can't do that either because one of the arms that pivot the wipers is not properly drilled to move the other wiper to the proper location. I will call Newport and attempt to get the proper arm to properly position the post inside the housing. Aside from that I don't like where the motor is going to end up once it is mounted. It will basically reside just above the rear view mirror in the truck which is not my preferred location. Another thing that I don't really like about the design is that the ends of the housing are completely open for spiders and other critters to crawl into and make a home. Should be sealed up a little better I think and the motor still sticks out about 4.75 inches off of the windshield frame so definitely not low profile.
In any case, after attempting to mount this in the truck I am going to pass on installing it and probably sell it. Although it is a decent/sturdy looking design I think that Newport kinda dropped the ball on this design for the Bronco Wipers. The wiper motor should be moved over toward the passenger side of the windshield frame and not positioned right above the rearview mirror.
I will be ordering the twin wiper motors from WH and the appropriate switch from cole hersee to get this done the right way IMHO. The setup that WH and some of the other vendors offer is definitely the lowest profile setup currently available and will yield the cleanest install IMHO. Hope that this helps anybody thinking about upgrading their wipers and not sure which setup to go with. ;D
BR549
huntsville
I need to replace my original vacuum setup. Who sells the kit you are describing. I would like to avoid aggravation if at all possible. Anyone got reviews on the bc bronco setup?
broncoitis
broncoitis
This thread was not a bash in any way on the Newport Engineering setup. I just tried to point out what I believe some of the shortcomings of the setup are as it stands right now. On the positive side of things it is an intermittent setup which is nice with high and low speeds! I am gonna get the right part from Newport to make this work in the Bronco and put this up for sale if someone is interested. If not I will keep it and maybe one day I will put it to use on another Bronco Project or something else! ;D
broncnaz
Sounds like the kit you got wasnt for a bronco. They claim there bronco kit just bolts in. Maybe you got a fullsized truck kit instead of a bronco kit. Might want to check on that.
JoePro
I figured this would be a good setup - that's what goes in the ICON's
bigjhoov
nobody
What year is your truck? The wiper spacing is different between the vacuum and mechanical linkage trucks. That may be the issue.
newport
Broncoitis,
I wish you would have called us about your issues and allowed us to clarify them before posting this. There are two different hole spacings. 19-3/4" and 24". There is no way to have just over 21" or what you were measuring. I don't remember what year your bronco was but we set up each kit depending on what year you have. Typically the 66-68 have the 24" setup and the 69-77 have the 19-3/4". Although 69's can have either one. And in some cases a later model windshield frame ends up on an older model. All you need is 3 different pieces to make it work. The placement of the motor is very close to the location of the original electric motor. The thickness to the unit is only 1" where the linkage and wiper pivots are located and just over 4" on the motor. It is much smaller than the original in respect to not needing the big bulky plastic cover and it looks much better than the original when the top is off. It does not stick up nearly as much as the original. We may come up with some caps for the ends. Yes these kits do go in the ICON Broncos and we worked with them to come up with this design. Sorry you are unhappy but I hope I cleared up some things.
Gavin @ New Port Engineering
jckkys
Gavin beat me to the punch. I ran into the same problem fitting a Toyota FJ40 '68-'74 wiper motor on my '68 Bronco. The 19 3/4" spacing is the same as FJ40s so Newport has another application/market for the '66-'68 Bronco system, and I have a backup plan if the FJ wiper goes belly up.
duffymahoney
I have the Newport wiper setup. I think it's a great design. I would love end caps though.
ared77
"and the appropriate switch from cole hersee"
What is this?
JaxLax
Jacksonville, FL
What is this?
See here.
The Newport setup comes with a rocker switch with arrows to control.
The above (from Cole Hersee aka LittelFuse.com) is an electric wiper controller [that does not work with self parkers] but it was a more stock style switch with sprayer control.
