Roy66
Okay, here is the story - modified 66 wagon with 302 based 347 stroker; full MSD including box, coil and distributor; new starter and starter relay; battery is optima red top, fully charged, but now new, approximately 8 years old.
All other electrics work, but on turning the key, relay activates but no crank and then everything is dead. I checked battery connections at the terminals - both tight and clean, negative has a quick disconnect.
At this point, I suddenly have power to all electrics again; turn the key, relay activates but again no crank and everything is dead - repeat.
Truck started with this setup a month ago, so what am I missing here? Possibilities - Is it the ignition switch? Is it the battery?
