Bronco Sport
ebman74 said:I replaced all lines. Still problems! I ran a line all the way from the pump to the gas tank and it worked.When I connect it to the fuel tank selector switch it won't suck gas! What possition should this switch, that is under the driver seat be in? I assume main for main tank! Could this thing be messed up or clogged? When I bought the bronco the switch was in the middle possition facing down?
Main is for the main rear tank and aux should be the front tank. Your switch could also be the problem. I could be wrong but mine would not run at all in the middle position. I would disconnect from the switch and bypass it all together, and try that. They can and do go bad.
