jerrybromley
- Sep 17, 2018
- 344
Can a vacuum assist be added to an early Bronco with manual brakes without changing anything else ?
I built my own with a mustang booster can. Has worked fine for me and I didn't have to dent the fender and can still remove the valve cover pretty easily.
Did you get this installed yet? Looking to install a power set up on my '68.Well I ordered my power assist from Toms .( They say no-modify). Not there yet but when I get everything installed and set-up I will post what I find....
YUP....I had power drums for 10 years. It worked great till a panic stop was needed and you never knew where the rig was going to dart. If you keep them adjusted correctly it's not as bad. I just drove in a bubble. Made sure everything stayed outside my bubble and drove much slower than I do now......I now have a different opinion on the power boosted drum brakes. I had to do a panic stop the other day. It scared the ever lovin crap otta me !!! I'm sure the drums were probably not adjusted properly but I played hell getting her under control. I have ordered a disc brake conversion for her. I should have it on sometime next week.
