I am helping a fellow bronco brother install a Centech harness on his fiberglass Bronco. We got the new harness in and everything seems to be working fine except we cant get it to start.
He is using the Duraspark ignition. Before we replaced the harness it did run but had an intermittent no start issue before and we were hoping the new harness would fix the issue.
My Bronco is next to his but has been converted to EFI so I cant just compare them.
We tried the old coil then replaced it.
We tried the old ignition module and a new one with no change.
At first we did not use the Ballast Resistor but now have it wired up.
It is acting like we are getting a very week or no spark from the coil.
What voltage should I be seeing from the positive side of the coil wire?
What voltage should I be seeing from the negative side of the coil wire?
How can I test the coil to make sure it is good?
