I've been doing a total rebuild on a 66 Bronco for the past year and finally have got to the point of trying to start it up. I installed a new Centech wire harness, but can't get it to start. It keeps blowing the fuse between the one wire alt. and battery. I know I'm overlooking something but can't see where. I would appreciate a new set of eyes looking from a different angle if there is anyone in the Cumming, Ga. area. If not I'll just keep at it.
Are you talking about blowing the big 150-200 amp Mega-Fuse thing? At what point does the fuse blow? When you hook up the battery?
Positive battery cable to the BAT+ side of the starter solenoid. STA side of the solenoid to the starter.
The "One Wire" from the alternator to the MegaFuse, then from the MegaFuse to the BAT+ side of the starter solenoid (effectively the Postive side of the battery).
Negative battery cable to the engine block. Ground strap from the engine to the body, and another strap to the frame.
Disconnect the alternator OneWire, and try to start.
