Be leary of excessive oil pressure. I rebuilt a 289 with mild mods, rv cam, alum. intake vs, iron and a "high volume" oil pump. I ensured that the cam and the distributor gear were of compatible metals. Ended up with 90 psi at start-up (100 psi mech. Autometer gage) and dropped to 70 psi when fully warm. 500 miles later, enroute from CA to 'Bama, the engine dies! Excessive drag on distributor/ cam gears wore the teeth to shreds and one tooth broke off. Replaced Hi-vol pump with stock unit and new distributor gear. 50 psi cold, 40 max when warm, 20 at idle.
