I have a 1976 with original c2 engine and 3 speed auto.
It has a new problem where it won't start after sitting more than a few days.
If I hit it with starter spray, it starts right up.
It has always started a little rough, but I have done some battery and cable work, plus replaced the starter. Of note I also replaced the fuel pump a few months ago.
Anyway, after sitting for more than a few days, it turns over and over but won't start. I can try turning it, flooring the pedal and turning, etc etc. If I remove the carburetor and hit it with even a little starter spray, it starts right up and runs fine. If I drive it later that day, starts fine. If I drive it the next day, fine.
Why does this happen? Does fuel settle out of the line over a few days and then can't get to the engine fast enough to start, even with depressing the gas all the way for a bit while attempting to start? Is it something about the mechanical fuel pump needing the engine turning faster than just the starter motor does?
Anyone else have this problem?
