Buddy's 70
- Jun 15, 2008
- 64
My uncle has a problem with his 435 grinding the gears when going from 2nd to 3rd only.It doesn't grind when he goes from 3rd to 4th, 4th to 3rd, or 3rd to 2nd, only 2nd to 3rd.He even double clutches when he shifts from 2nd to 3rd and sometimes it still grinds a little. The trans has a rebuild kit put in it and a local shop says everything looks good inside and should work fine(they didn't put in the rebuild kit). It also had a new clutch put in on the original installation and has about 2000 miles on it now. My uncle has called several other shops and no one has any idea what could be wrong, but would like him to bring it in to look at it,of course. The trans is mated to a 351 Windsor. I know a lot of Bronco brothers use this trans and was hoping someone has some insight on this particular problem.Thanks in advance!!:-[
