Guys/gals, for your consideration is a NP435 ready to be installed in your EB. I rebuilt this transmission for a gentlemen who was going to install it in his '66 EB, however, he backed out due to unexpected problems with the motor he was getting ready to build/install in conjunction with this trans.
This transmission was pulled from a low-mile 1986 F150. It originally came with a long, 31 spline output shaft. I disassembled the trans, cleaned it inside and out, inspected it, and installed a 28 spline short output so that it is ready to be mated to a EB Dana 20 using your choice of adapter. This transmission is in excellent condition! The gears and synchros are in great shape. I also added new seals when I went through it and installed the new main shaft. I also have a manual-clutch bellhousing for a small-block Ford motor if you need it.
Why spend $900 from Tom's or elsewhere when you can get this one for less than half that!?!
I am in central Florida between Tampa and Orlando.
NP435 - $400obo
NP435 - $400obo
