np435/t18 same adapter?
bnk70bronco
Redding, CA
Do the t18 and the np435 with the trapazoid pattern use the same adapter? I have an adapter but am not sure what tranny it is for made for.
Anywhere cheap to get a 28 spline output shaft?
BroncoJAK
I do know that the same adapter for the square bolt pattern works for either one. I have an Advanced Adapters behind an NP435, and it has T18 cast into the top. Anyone else? I know there have been some to use the 4wd NP435.
jeff71sport
Tacoma,WA
I have the 4wd version of the 435 and it has the trapaziod pattern but i have not had a good look at the t18.. as for the output shaft i bought mine from Tom's Bronco for $100-130$
jeff
bnk70bronco
bnk70bronco
Redding, CA
Here is a pic of the adapter I have. I was thinking I could just drill two new holes on the bottom and it would work for the square bolt pattern? or it the top two bolts on the trap pattern closer together than the square pattern top bolts.
