Junk Yard Run; np435 or t18?
75Bronc
A buddy of mine owns a small ford junk yard, and im going to run out there to get some stuff. Im running a c4 atuo and am going to convert to a np 435 or t18. I was wondering what you guys thought would be a better transmission, and what parts would be accebtable to get used from the junk yard such as the trans and bell housing? And which parts i would need to get brand new.
sworddancer
Corpus Christi, TX.
Remember T-18 is longer but uses the same adapter so the driveshafts will most likely have to be modified. The 435 also has a little bit lower granny gear. Most hard parts are fine from a junk yard but gettin harder to find the right parts. Obviously get a new clutch, but a bellhousing and the transmision (assuming it turns and shifts OK) should be fine out of a junk yard. the 435's and T-18's were beefy enough it took alot to hurt one. Might get it rebuilt with new bearings or syncros though. Make sure you get the right model 435 as the ones we want are rare these days (look at the vendors discriptions).
75Bronc
75Bronc
yeah is there anything else i can get from the junk yard other than the bell housing and tranny itself?
fordtrucks4ever
DFW
All of the clutch linkage may be a little difficult to locate. You might look into a hydraulic clutch if you dont find the stock linkage. Both those trannys came in all makes of trucks. Just make sure you have the Ford/Jeep bolt pattern for bellhousing. Depending what part of the world you are in may lead to someone with extras sitting around. The cast iron bellhousings used to be plentiful and still are to veteran Bronco owners. You might be able to find a later model bellhousing(80's) already equipped with hydraulic clutch parts too. Could make it a little easier on the conversion.
chris
No more Rock Crawler
NP435, nothing like putting it in 1st gear and just walking up the rocks. :cool:
TOOLMAN
I love my NP435. Sworddancer is correct in saying the the T18 is longer so drive shaft lengths will need to be changed. If I remember correctly, you have to get an NP from an early to late '70's (don't know the exact years) 2wd truck. It's been a few years, so someone tell me if I'm wrong. I think mine came out of a '75 F-150. If you get one from a 4wd, you have to change the output shaft (again, if I remember correctly). I think the biggest cost of installing that thing is buying the adapter to the D20. It cost me more for that than the transmission ($100) and rebuild of it.
BTW...I don't think I needed any bellhousing or linkage. I just used my OEM Bronco stuff.
Broncoman
You need a 2wd drive np435 if you want to use the cheaper adapter for the dana 20. The only catch is you need the 28 spline output shaft not the 32 spline. They switched to the 32 around around 73 if I am not mistaken.
Oh and I am a fan of the Np435........never owned a t-18 though
The existing 3-speed bellhousing should work just fine, no need for the NP435 bellhousing.
bmc69
Except he's running a C-4 now.;D
It will be hard to find the NP-435 on a 302 bell housing. You will most likely need to get the bell housing from 'something' else to go with the NP-435 (or get on from a fellow EB person)..unless you are lucky and find the 435 behind a 300 I6..you can use that bell housing.
TOOLMAN
You're right bmc. I forgot he was running a C4. My buddy has a T18 in his '79 F-250 and he likes it a lot. From what I understand really the only differences between the two is length (obviously), first gear ratio (as aforementioned), and the T18 has a cast iron cover; whereas the NP has an aluminum one.
sworddancer
Corpus Christi, TX.
The JBG website page for manual transmission has a page with all of the possible parts you could need. Take a good look at the clutch page. I'd take a look at the page so that you know what parts you are looking for/at while at the junkyard and know what they might be worth. Most of the JBG parts a new though.
kyle
If you are going to stay with the Dana 20 TC, there are no advantages to a T18. Go with the 435.
Scrapper_MV
A good friend of mine has a Scout with the T-18 and a Dana 20. I have driven both in the rocks and I much prefer my NP-435 with it's low first gear.
Buldozer
Bronco Virtuoso
God's Country
This is a no-brainer if you wheel a lot...the NP435 is hands down better for slow trail riding and climbing IMO. Good luck.
