Nut, bolts and f@#$ing screws
Smedley
Snohomish
Completing a frame off resto. Chassis is mostly complete and painted body is now on chassis. I have mostly everything I need to put it back together, except for all of the broken, stripped and rusted nuts, bolts and screws I removed when I disassembled. What a pain in the ass. The majority of my time is running back and forth to the hardware store for one or two nuts, bolts or screws. Rant over. Is there a comprehensive list of what size nut, bolt or screw is needed (for everything)?
Will
tasker
all knowing of nothing
NH
I FEEL your pain Will! everytime I go to Tractor supply I buy a pound of hardware! now I just lose the whole bag :cool:
jmangi62
I've been there too, literally wore a path leading to Fastenal and Tractor Supply. Check Bronco Graveyard, I think they have complete kits for body and chassis. Good Luck. Jim :cool:
904Bronco
San Martin, CA
I feel your pain as well...
I know the nut and bolt section of my local Ace Hardware better than the folks that work there.
Bought so many small bags of hardware at Fastenal that they asked me to open an account!
centex77
I've spent a small fortune in stainless hardware at Home Depot doing the build on mine. Seems like every time I start to work on something I have to stop and go to the store to buy more damn bolts. The below thread had some good information on nuts and bolts. The pre-packaged bolt kits are nice but they don't include things like dash mounting hardware, or pedal mounting, or underbody stuff, or seats, or windshield, hood, etc. And if you are doing something custom or different you are on your own.
http://classicbroncos.com/forums/showthread.php?t=284566
Pops68
Bronco Rookie
Bazetta Township
I thought most of the vendors at the top of the page had 'complete' hardware sets.
catfan
If you have a Rural King in your area they are cheaper than any, they also have grade 5 and 8 plus metric. The grade 2 stuff is 1.49 a pound.
fosgate150
See below....
Location Qty. Size Type Notes
Motor Mounts 2 1/2 Flat Washer
T-Case Crossmember to Support Angles 2 1/2 Flat Washer
Fender Support Brace Rods 12 1/4 Flat Washer
Cage Mounts 24 3/8 Flat Washer
Hardtop (Bedrails) 14 5/16 Flat Washer Use on nut or 2 per if not integralcarrier
Hardtop (Windshield) 9 5/16 Flat Washer Use on nut or 2 per if not integral
Seats (Front) 6 5/16 Flat Washer Stock is integral with CS
Seats (Front) 3 5/16 Flat Washer Stock is integral with CS
Torque Convertor STK 16 3/8-24 Flanged Stover Nut
Track Bar Mount (66-75, Axle End) 1 3/4-16 Castle Nut
Heater Core 4 1/4-20 Nylock Nut (GRD 8)
Cage Mounts 24 3/8-16 Nylock Nut (GRD 8)
Hardtop (Bedrails) 14 5/16-18 Nylock Nut (GRD 8)
Hardtop (Windshield) 9 5/16-18 Nylock Nut (GRD 8)
Soft Top Header 9 5/16-18 Nylock Nut (GRD 8)
Body Mounts 8 7/16-14 Nylock Nut (GRD 8)
Front Bumper (Hanson) 4 1/2-13 Stover Nut
Motor Mounts 2 1/2-13 Stover Nut
T-Case Crossmember to Support Angles 2 1/2-13 Stover Nut
Coil Spring Upper Mount 2 3/8-16 Stover Nut
Leaf Spring Hangers 4 5/8-11 Stover Nut Flange nut prefered
Leaf Spring Hangers 2 9/16-12 Stover Nut
T-Case Bushing Mounts 2 9/16-12 Stover Nut Stock uses 9/16-18 Castle
Track Bar Mount (66-75, Frame End) 1 9/16-12 Stover Nut Stock uses 9/16-18 Castle
9" Third Member 10 3/8-24 Stover Nut
Radius Arm Nut 2 3/4-10 Stover Nut Stock is Castle
Body Clip Nut STK 50 5/16-18 Short throat
Leaf Spring Hangers 2 9/16 Flat Washer heavy duty
Rock Skis 20 5/16 SS AN Washer
Soft Top Bedrails 14 5/16 SS AN Washer
Soft Top Header 9 5/16 SS AN Washer
Fenders (rear edge) 2 5/16-18 x .7500 PHMS Phillips head
Door Striker Post 2 5/16-18 x .500 CSK Screw Phillips head
Tailgate Catches 4 5/16-18 x .750 CSK Screw Oval head Phillips
Tailgate Release Handle Bucket 4 1/4-20 x .500 CSK OHMS Phillips
T-Case Crossmember to Support Angles 2 1/2-13 x 1.500 GRD 8 CS
Front Bumper (Hanson) 2 1/2-13 x 1.250 GRD 8 CS
Front Bumper (Hanson) 2 1/2-13 x 6.000 GRD 8 CS
Tailgate / Liftgate Anti-Rattle Tab 2 1/4-20 x .500 GRD 8 CS Stock with integral washers
Tailgate Release Handle Bucket 2 1/4-20 x .500 GRD 8 CS Stock with integral washers
Fender Support Brace Rods 12 1/4-20 x .750 GRD 8 CS Stock with integral washers
Cage Mounts 24 3/8-16 x 1.000 GRD 8 CS
Coil Spring Upper Mount 4 3/8-16 x 1.000 GRD 8 CS
Coil Spring Lower Mount 2 3/8-16 x 1.250 GRD 8 CS
Pedal Assembly / Brake Booster Bracket 2 3/8-16 x 1.250 GRD 8 CS Stock with integral washers
Pedal Assembly / Brake Booster Bracket 5 3/8-16 x .750 GRD 8 CS Stock with integral washers
Tailgate Hinge Pivot 4 3/8-16 x .750 GRD 8 CS Stock with integral washers
T-Case Crossmember Support Angles 8 3/8-16 x .750 GRD 8 CS
Door Hinge Post 12 5/16-18 x 1.000 GRD 8 CS Stock with integral washers
Hood Hinge 4 5/16-18 x 1.000 GRD 8 CS Stock with integral washers
Seats (Front) 9 5/16-18 x 1.000 GRD 8 CS Stock with integral washers
Tailgate Latch 4 5/16-18 x 1.000 GRD 8 CS Stock with integral washers
Core Support to Grille 3 5/16-18 x .750 GRD 8 CS Stock with integral washers
Fenders 14 5/16-18 x .750 GRD 8 CS Stock with integral washers
Hardtop Corner Posts 14 5/16-18 x .750 GRD 8 CS Stock with integral washers
Steering Column Firewall Mount 3 5/16-18 x .750 GRD 8 CS Stock with integral washers
Dana 44 Cover 10 5/16-18 x .625 GRD 8 CS Stock is flange head
Leaf Spring Hangers 4 5/8-11 x 4.500 GRD 8 CS
Bellhousing to Engine (C4) 6 7/16-14 x 1.750 GRD 8 CS
Body Mount (Front Clip) 2 7/16-14 x 3.000 GRD 8 CS Stock is 3/8-18, add for body lift
Body Mount (Driver/Passenger) 2 7/16-14 x 3.500 GRD 8 CS Stock is 3/8-18, add for body lift
Body Mount (Behind Front Seats) 2 7/16-14 x 4.500 GRD 8 CS Stock is 3/8-18, add for body lift
Body Mount (Tailgate) 2 7/16-14 x 4.750 GRD 8 CS Stock is 3/8-18, add for body lift
Radius Arm Caps 8 9/16-12 x 2.500 GRD 8 CS
Track Bar Mount (66-75, Frame End) 1 9/16-12 x 3.000 GRD 8 CS Stock uses 9/16-18
T-Case Bushing Mounts 2 9/16-12 x 4.000 GRD 8 CS Stock uses 9/16-18
Rock Skis 20 5/16-18 x .750 SS BHCS
Soft Top Bedrails 14 5/16-18 x .750 SS BHCS
Soft Top Header 9 5/16-18 x .750 SS BHCS
License Plate Frame Bracket 7 10-24 x .375 CS Thread Cutting
Heater Core 4 1/4 Fender Washers 1.000 OD
Seats (Front) 5/16 Fender Washer
Steering Column Firewall Mount 3 5/16 Fender Washer 1.250 OD
T-Case Crossmember to Support Angles 2 1/2 Lock Washer
Coil Spring Lower Mount 2 3/8 Lock Washer
T-Case Crossmember Support Angles 8 3/8 Lock Washer
Bellhousing to Engine (C4) 6 7/16 Lock Washer
Radius Arm Caps 8 9/16 Lock Washer
Body Mounts 8 7/16 Fender Washer 1.500 OD
Hardtop (Bedrails) 14 5/16-18 x .750 GRD 8 CS Stock with integral washers
Hardtop (Windshield) 9 5/16-18 x .750 GRD 8 CS Stock with integral washers
Leaf Spring Hangers 2 9/16-12 x 4.000 GRD 8 CS Flange head prefered
Liftgate support arm lower mount 4 1/4-20 x PHMS Phillips head, thread cutting
Radius Arm Bushing Washers 4 1.000 Fender Washer 2.500 OD
Tailgate Support Linkage 8 5/16-18 x GRD 8 CS Stock with integral washers
Track Bar Mount (66-75, Axle End) 1 3/4 Fender Washer 2.375 OD
Skiddy
Pretty sure both JBG and WH have kits. I bought a kit from JBG for the front clip at least.
I did that as well, then had to back and grill trim clips.
I have been getting a pound of hardware at tractor supply about every trip I make lol
Smedley
Smedley
Snohomish
I got the kits for the front end body parts. Its all the interior stuff. Just ordered a few kits from Toms. Getting there......
D.R.Y.
The Netherlands
I bought a kit from TBP but still have to buy alot at Tractor supply on my trips to Texas. I think 5l-10lbs of my luggae was nut, bolts and washers. Pain in the ass to get non metric in Netherlands
69_Sport
Amk is the way to go for me. They are a godsend when restoring an old Ford. Hardware store bolts look out of place to me. Quality AN or grade 5 or 8 hardware is really expensive when buying a few at a time. Ford used specific hardware that for the most part is not available at the hardware store. Amk kits come bagged and tagged to make it easy. I tend to lean toward the resto vs modified camp, so the original look and finishes are important to me. I have used Amk products on more than one Mustang I've restored, so I naturally went to them for Bronco fasteners.
SteveL
Huge chevy guy
Hawthorne ca
See below....
Text that over to grainger and wait for a response
