NV3550 Shifter and shift stick extension
rockingm82
St. Peters, MO
I bought my adapter kit and NV3550 separate, therefore there is was no shifter.
I know there are three different shifter options for this transmission. What do most use? The Jeep shifter? I also want to have JB Fab me stick to match there twin sticks, but they need something to model it after. What stick conversion do you all use with your NV3550?
Godwick
Santa Barbara, CA
Get the core shifters adapter and the jb knob. Boom. Quick shifting and matching... Kinda
blubuckaroo
Grease Monkey
Ridgefield WA
I use the B&M shifter. It matches my JB transfer case shifter handles.
It also has a shorter throw than the stock shifter with a stock or aftermarket handle.
rockingm82
rockingm82
St. Peters, MO
Found an older thread with more info. http://classicbroncos.com/forums/showthread.php?t=266816&highlight=Shifter Sounds like whichever I use will have to be modified.
I'm think something like this http://www.ebay.com/itm/Jeep-NV3550-Transmission-Shifter-Tower-Assembly-30616-/301398882109 Then mocking up a stick with length and angles using something cheap and then send that off to JB Custom to have one fabbed up. Thoughts? What could I use to mock up the stick that would be cheap and easy to bend?
blubuckaroo
Grease Monkey
Ridgefield WA
That factory equipment shifter base is well made, however no matter which handle you bolt onto it, the throw is going to be really long. We first noticed it in my sons TJ. It feels a lot like you're rowing a boat.
As long as you're going to be buying the whole assembly anyway, why not get a CORE or B&M with a close throw?
rockingm82
rockingm82
St. Peters, MO
Excellent. Didn't know about the throw distance on stock shifters. I'll definitely look at the two mentioned. Originally, I was looking at the $$$. Good thing this site exists!
