NV3550 shifter opinions
blubuckaroo
Grease Monkey
Ridgefield WA
I've had my NV3550 running for a while now. That and the differential re-gearing are the most effective upgrades I've ever done to the car. I'm really happy with it.
However, soon after the install, I became unhappy with the long throw of the factory shifter. It was a lot like rowing a boat.
That's when I replaced the original shifter with a shorter throw B&M shifter. This really tightened up the stroke however, because it changes the fulcrum point, it also narrowed the shift gate considerably.
It drives well for me, but it takes a bit of getting used to. Drivers new to the car often struggle finding the gears with such a narrow gate. My wife is now reluctant to drive the car.
I'd like to hear from others who have experienced both the original and B&M shifter on their NV3550. Which do you prefer?
I've still got the original shifter, and will probably reinstall it to make driving easier for others.
SHX669
I actually didn't dislike my original shifter but had to replace it because the composite part of the shift tower cracked and Jeep wanted a fortune for another composite one.
Like you I had a little trouble getting used to the narrowed shift pattern after a couple of years of "rowing the boat ' . I also find it harder to tell what gear I'm in ; I usually go by " sound " or reach over to feel where the shifter is " parked " . And like your experience people unfamiliar with it have a little trouble finding the gears . The girlfriend usually shifts to 5th when shooting for 3rd.
If I still had the original I would reinstall it just to see how it compares to the B&M now that I've driven it for a couple of years. that might be the way to tell which one you like better . - So that's my opinion - LOL
Oh - I did bend the shift rod on the B&M to get it closer to me and further from the dash.
blubuckaroo
blubuckaroo
Grease Monkey
Ridgefield WA
I think I will change back to the original shifter, to see if it makes a difference for my girl.
I was going to pull it anyway to do an oil change. I like to overfill it 1/2 quart.
