smokinjoe
Gotta an interesting one for ya', 76 carb'd 351, mechanical OE pump. Running a 351 (D2AE) outta a 72 full size car (I usually tell them a 72 Galaxy 500 351ci at the parts store)
Fuel pump diaphragm crapped out, leaked gas into the crank case. Pulled off the pump and drained the fresh oil I just put in %)
The fuel pump that came OFF the rig has the supply (input) hose barb on the right hand side of the pump (when staring at the front of the pump from the driver wheel). The output side going to the carb has flare/compression fitting type connection to the bent hard line to the carb.
The new pump has the hose barb on the left side and the compression fitting on the right side, the opposite of the pump that came off? Tried pulling a pump for a 76 EB as well, same part # as the 72 351 Galaxy.
I can make it work but my question is do you think on the new pump that the fittings are reversed? Input on the left and output on the right? Or is it still output on the left and input on the right like the pump came off? Obviously I can make it work but WTH? Why does this truck always fight me?
Your help is appreciated I actually am trying to get it running for a test drive for a potential buyer
