OE steering column color match
jckkys
The OE color is a semi gloss dark grey that's almost metallic. The closest I could find is semi gloss black, that matches the pebble grain bezel on the dash. Is there a rattle can match for the OE color? Something that's durable would be good too.
sprdv1
REBEL
isn't there normally always an original OE color match for most vehicles?
I would "think" there would be, but could be wrong. maybe not for the column itself
bump for ya anyway
J
jckkys
Thanks. I did one column with semi gloss black. It looked good but not exactly like original. Unless you had seen a lot of Ford truck columns you'd never know.
I wonder if one of the darker versions of a metallic "bronze" would do it?
I know the basic versions would have too much brown in them, but I've seen some that were pretty darn dark. Almost black.
Might at least be worth a check.
Scoop
Bronco Old Fart
Cuchara, CO
This sounds funny but I got a good match using VHT Black Pearl paint and then covered it with a clear satin. Turned out awesome. The satin clear tones down the pearl and makes it look slightly metallic. I did the column and the wheel on the half cab I sold at Mecum last week.
