DJs74
- Apr 1, 2014
- 1,135
yea it was 15in steady on the vacuum. i tired to day and capped the pcv port and didnt change anything. as far as i know the motor internally is stock. ive tried with this new pertronix dizzy at 8 9 10 and 11 deg of timing and didnt change anything either. i looked for a vac leak but could not find one. should i try more timing than 11? ive also played with the idle screws. starting at about 3/4 and working my way out and still nada.
My original suggested vacuum range of 15 - 20+ was based on unknown internals like camshaft, etc. For a stock engine with a 4 bbl intake added - I agree the vacuum should be right around 18 - 22 inches (easily).
Is there any way you can borrow or might have access to another carburetor to try? Basically process of elimination... I wish you were closer, I have 3 extra here you could try.
If you cannot adjust the bogging out with carburetor changes and timing changes - I really suspect an internal vacuum leak with the intake. These intakes (especially BBFs) are very picky about the torque sequence and values. If the intake is not toruqed down properly, you can potentially have a vacuum leak between cylinders and not necessarily a vacuum leak to the outside world -thus, the carburetor spray is of no value because the intake is actually sealed off externally.
The air / fuel mixture screws should be somewhere between 1.5 - 2.5 turns out as a starting point & general rule of thumb. Once you unscrew them to a certain point, there is no longer any change because the screw is not restricting the port at all.
If possible, try to use a vacuum gauge while adjusting the screws - your are looking for max vacuum at idle. Also, try to keep the screw adjustments equal between both sides and try 1/4 turn at a time adjustments.
DJs74
