Oil pan/dip stick advice
gunnibronco
Gardnerville, NV
I pulled my oil pan off to do a rear main seal and fix the oil leak at the dip stick fitting. The dip stick tube threads into a cast piece that is on the inside of the oil pan. I drilled the rivets, cleaned everything up, threaded the rivet holes for bolts. I installed a new gasket and sealant between the cast piece and oil pan. When I filled it, the bottom two bolts were still dripping a little oil. So I put a wrench on them to see if they could be snugged up better. I've now pulled the threads on one of the lower bolts (probably on the cast piece, I'm guessing). I was not putting too much pressure on the bolt when it let go, so I bet my threads in the cast weren't great, or the cast piece is weak.
I need to pull the oil pan and fix this again.
Has anyone had luck reusing the new style rubber oil pan gaskets? Or should I just buy one and replace it again? I feel like it should be reusable, but I sure as hell don't want to be doing this again because I reused the gasket. (FelPro OS13260T)
Can the cast piece in the oil pan be welded? I really planned to weld everything instead of using the gasket, but I didn't when I saw the piece in the pan was cast.
Or is there another way to do this without a new oil pan and a dip stick in the timing chain cover? I'd just like to minimize the work and get this up and running.
SteveL
Huge chevy guy
Hawthorne ca
As far as the gasket you answered your own question. Do you want the chance of doing it again over a couple dollar gasket. Timing cover dipstick won't work with the rear sump pan. As far as sealing it up not sure of best plan since I haven't dealt with that issue. You could go full redneck and jb weld it
56f100bbw
Tucson / lakeside AZ
drill out the revits drill and tap and . Thread the cast-iron make a gasket and no leaks A little bit of RTV on both sides of the gasket Thread sealant on bolts
Wouldn't surprise me if you found the oil was weeping through the threads of the bolts and not leaking through the gasket itself.
The all rubber/silicone gaskets are sometimes reusable. Was there any damage as it came off? To that I have reused cork valve cover gaskets more than once as well. So long as they are in good shape coming apart.
gunnibronco
gunnibronco
Gardnerville, NV
So I guess I got lucky. Turns out the Chinesium bolt stripped, not the threads in the cast piece. I replaced the stripped bolt with a new one and it's not leaking.
Since I didn't have to drop the pan I didn't have to choose to reuse my gasket or not. If it wasn't $50 I wouldn't care.
Sent from my E6910 using Tapatalk
