so you made that fitting or made it yourself?The pan fitting could be leaking mine was made a new gasket and drill and tap the cast iron fitting fixed it
Typically it is just a matter of drilling out the rivets and replacing the gasket. No new oil pan fitting, just resealing the existing one to the pan. I've seen people make new gaskets, just use RTV, and in one case got a torch and brazed the cast dipstick base to the side of the pan. Lots of different ways of doing this.so you made that fitting or made it yourself?
Yes just drill out the revits and I used a #27 drill bit and pan head bolts 1/4 -28 thread 1/2 long and cut out a new gasket 3/8 fuel line with fitting screw right into the cast iron in the oil pan .Typically it is just a matter of drilling out the rivets and replacing the gasket. No new oil pan fitting, just resealing the existing one to the pan. I've seen people make new gaskets, just use RTV, and in one case got a torch and brazed the cast dipstick base to the side of the pan. Lots of different ways of doing this.
The cast iron 4 bolt plate inside the oil pan is original bronco I just blasted it clean I think later pans were screw in not slip inso you made that fitting or made it yourself?
what year is your oil pan? did they put thread in all years? If so that's a easy fix< thanks for the help.The cast iron 4 bolt plate inside the oil pan is original bronco I just blasted it clean I think later pans were screw in not slip in
Mine are 76/77 easy fix fun part is pulling the pan not all years we’re not threadwhat year is your oil pan? did they put thread in all years? If so that's a easy fix< thanks for the help.
Here is how I did my 72. As stated, pulling the oil pan would be the hardest part of this mod. Drilled out the dipstick boss and threaded it with a pipe thread die and tack welded some nuts inside and bolted the boss to the pan. Works well.
I've had to sort out wrong dipstick lengths a couple of times. Here's what I did. Park on level ground. Do an oil change, fill it per the manual, but leave it 1 quart low. Run the engine to fill all passageways & the filter, & to warm everything up. Allow it to sit & drain down for awhile. Use the dipstick & mark the low line. Add the last quart, allow it to run down to the pan for awhile, then mark the full line. If it's cold you could run the engine again to warm all the oil so it drains well before marking the full line.FYI, when you start playing with the dipstick tube, you have to pay attention to the dipstick as well. The lengths are a matched pair. The tip of the dipstick (actually the low and full lines) need to be at the correct altitude in the oil pan. If you end up changing the length of the top of the dipstick tube you will change the height at the bottom of the stick. And the marks will no longer be correct.
