Oil Pan Dipstick
brbuilder
My ‘69 302 had the dipstick location on the passenger side of the oil pan plugged with a wooden dowel and covered with silicone gasket sealer. Guessing it had been leaking and it is leaking again. The dipstick tube, currently located in the front covers appears to have been removed and relocated from the oil pan location. It doesn’t fit very well, is not in great shape and does not seal to the cover very well. While upgrading to the 3g alternator I changed out the dipstick tube in the front cover and noticed that the old and new dipsticks are too long. They hit the bottom of the pan With about 1.5” sticking out of the top of the tube. Keep pushing and the dipstick bends along the bottom of the pan until the cap seats at the top. (Don’t know why I hadn’t noticed this before) Same for both the old and new dipsticks. Both dipstick tubes are the same length. I’m wondering how accurate is the oil level reading.
Would it be better to use the front cover dipstick location? Cut the dipstick so it doesn’t hit the bottom of the pan, fill with 5qts of oil and make new marks, if needed on the dipstick. (Assume filter holds 1qt)
Or buy a new press in dipstick tube for the passenger side dipstick tube location in the oil pan? Will need to replace the gasket at the dipstick tube to pan assembly.
Best way to plug/seal whichever location is not used?
Any preference/benefit to one location over the other?
brbuilder
brbuilder
Thanks for the reply but my oil pan does not have a threaded connection for the dipstick tube. It’s just a push in/press fit.
jckkys
I'm going from the Fox/Panther duel sump 351 pan to the real Bronco pan modified at the rear main girdle to work on my 351. I measured the dip stick mounting plate hieght of both and they are the same so the dipstick penetrates the oil to the same depth. The Fox/Panther dipstick should work well in an EB pan. The timing cover dip stick won't work with any rear sump pan. The oil isn't in the front. It's in the back. The EB pan barely has room for the oil pump. When Gary's Auto Machine Shop on 17th St. is done with my engine, in 2 weeks all the parts will be at Hot Rods on south Houghton Rd. I can meet you there and go over your situation with Adam the shop mechanic and master welder. I also have a spare duel sump dipstick you can have. Just PM me.
englewoodcowboy
Lick Creek Restorations
Unfortunately no one makes a flexible dipstick for the stock pan until.... Be on the lookout to have an offering. It utilizes Lokar parts but has to be machined etc. to work on the early bronco push in type. I just finished designing, building and prototyping it as well as calibrating it for the proper oil level to be accurate. Hang tight, it will be coming soon and I will make a post for it but it wont be cheap due to the extra work that has to go into it.
bronkenn
Bronco Guy
Southeast Ohio
It is not a hard mod to do if you have your pan out. I drilled out the 4 rivets holding the dipstick in the pan and took the inner plate and flipped it over and mounted it to the outside. The inner plate has a thick boss that can be drilled out and tapped for the threaded in dipsticks. I welded nuts inside the pan if it ever needs serviced, it can be removed without dropping the pan. Put a good gasket/sealer on it and bolt it in. I haven't had any issues with it so far. Ken
mp
Austin, TX
Nice work! And cheap upgrade with entry level mods you can do in the garage. Would be interested in seeing your gasket.
bronkenn
Bronco Guy
Southeast Ohio
I believe I made one with gasket material and I use Aviation gasket sealer on both sides of the gasket.
englewoodcowboy
That is ok and all but there is a reason that inner tube extends so low into the pan. It is to stop rotational sling of the oil up the tube thus pressurizing the tube and forcing oil out of it. You may be OK with the dipstick but don't be surprised if it does. I am working on a modified Lokar that will work in the factory location, it will just be a bit before I have it finalized. In the process of testing it now.
brbuilder
brbuilder
Bronkenn I came across your mod and thought it was a good solution. I was wondering why the tube was so long inside the oil pan. Have you noticed any issue with oil coming up the dipstick tube?
Englewoodcowboy, I’d also like to see pic’s of your mod.
bronkenn
Bronco Guy
Southeast Ohio
I put almost 2 thousand miles on it last year and haven't had any issues with it. I have not seen any residual oil up the dipstick when I check the oil. Maybe if the PVC system wasn't working right it could build up pressure in the crankcase and push oil up the tube but there is an O-ring on the top of the dipstick that seals pretty good.
huskybul
I also used Ken's solution to my leaking oil dipstick last year. I put up with it until I replaced the long tube headers with shorties and decided to do something about it. The most critical part of it was to find a flexible replacement with the 1/4 - 20 thread and ended up with the same one from Jeg's. Have had zero issues with it - thanks Ken.
bronkenn
Bronco Guy
Southeast Ohio
Thanks for the feedback. That is what I like about this site. A lot of good tips and ideas from so many members. Glad it is working out for you.
englewoodcowboy
Here you go.
Dandesjar
Thinking of attempting this mod while my oil pan is off.
Do you guys have a brand/part number for the dipstick you used?
Also, are you still happy with your mods? Have you found any downside to flipping the flange around and running it this way (ie. oil spewing out of the tube as Englewood Cowboy suggested)?
I’d hate to drill out the dipstick flange and then find out later that I needed that inside tube piece intact. These pans aren’t exactly easy to replace where I’m from.
DeepC73
Here you go.
Did you ever finish the “oil pan mod”? I’m looking everywhere for it. I have a factory slip in dipstick tube that’s leaking everywhere. Before I buy a new pan I wanted to try your fix. Any help is appreciated.
56f100bbw
Tucson / lakeside AZ
Dip stick
On dipstick modification drill out revits ,drill cast iron plate #3 drill bit and tap with a 1/4x 28 thread make a gasket with small amount of RTV on gasket and thread sealer on bolts and looks factory to me . I have done several and no leaks so far
salineriverman
Wilmar
Good evening Kenn- I know this is an old thread but I have a couple questions - what size tap did you use - I’m having trouble finding the 1/4-20 ? Is it an NPT threads or something else? Also my bronco has an 302 engine out of an econoline van - I think it’s a 1971 but not sure. The number stamped on the oil pan is DITE-6675-BA - I’ve got my pan off and the inside looks like yours- have you had any blow back issues yet? I know it's been a few years - would you still do it the same?
It was my late brother's bronco and I've been working on it - just like interior and oil pan I hope!! Thanks for your reply
salineriverman
Wilmar
My old dipstick was hitting the new shorty headers and couldn't get stick in or out worth a hoot!! Also what size drill bit did you use to drill out old tube- I think I read 7/16" some where.
