scottmcwms
Ok, so the time has come to finally start up my engine after 18 months of frame-off restoration. I completely rebuilt the engine so I decided to prime the engine with oil by spinning the oil pump with a drill before actually starting the motor.
I got a 1/4" long socket driver and started turning it by hand to make sure everything was turning freely. Then I hooked it up to the drill. I spun the oil pump counterclockwise to run the pump. I noticed for the first couple of revolutions it spun pretty freely, but then it started resisting more. My drill was working pretty hard to turn the pump. I could still turn it by hand but it required more effort than before. I put my torque wrench on it just so I could give a numerical value for how much it was resisting, but it didn't even register on my wrench which has a minimum torque value of 5 ft-lbs. So, the question is whether or not I have a problem here or is the pump performing normally. I have never primed an oil pump before, so I didn't know what to expect. And YES I do have oil in the oil pan!
Next, what do I need to do before I start up the engine. I have been filling the radiator for about a week now. It seems to be filling up finally. I filled the powersteering pump with fluid and it is ready to be bled. I need to put gas in the tank and prime the line. Battery is charged. Other than that what else do I need to consider before I start the engine?
Scott
Scott
