I am having my kids assemble the long block for my DD Bronco. It is a very low miles -almost new and started once-86 Lincoln 5.0. It has an aluminum oil pump and the nylon timing chain. Both clean and the chain is tight.
The way that I play with my cars, it is unlikely that I will drive with these for more than 5k before I put an explorer engine in it.
Should I be concerned about the timing chain and oil pump? Reason I am asking is that the timing chain is nylon on the cam sprocket and the aluminum OP makes me wonder?
Are there durability issues with those?
Thanks as always,
Rob
Thanks as always,
Rob
