Old American 5 spoke torque thrust
56f100bbw
Tucson / lakeside AZ
I have a set of 4 old torque thrust wheels 15x8 1/2 has 5 1/2 bolt pattern has anybody modified the front wheels to fit the front hub .Wouldnt let me post a picture. 2 of my wheels I changed the bolt pattern from 4 3/4 to 5 1/2 I have a machine shop guy to do the work but need idea of what it would like before I do it anybody got a picture
Tugross302
I think you’d get an answer quicker if you posted this in the tech section
56f100bbw
56f100bbw
Old Americans 5 spoke
Here is what I got
56f100bbw
56f100bbw
5 spoke wheels
I have these 5 spoke made by ET but not the same I put them on my bronco trailer wheel on the right
Well, I think they'd look very retro-cool, and unusual at the same time. Unusual because I don't remember ever seeing any of the old style spoke wheels like that on an EB.
But my thinking just by looking at it is that any machinist would be very reluctant to remove enough to make the hub bore large enough.
Can you give us the dimension that it is now, and what you would have to cut into to get to the needed size?
Maybe even a circle photo-shopped into the pic.
I'm just thinking that it's got to go too far, but you're the one there with the wheels. Maybe I'm just not seeing it from the pics. But I also remember those holes and their caps being pretty darn small.
Also, what's the backspacing on these? They look to have minimal backspacing by their cool "deep" look. But I don't know what that used to equate to on a car wheel.
What year Bronco are you hoping to get these fitted to?
And do you have the GM or Ford disc brake package? Some of these old wheels had pretty thick cross sections and might rub the backing plates. Worth looking into before machining I think.
Crush
Greenbottom, WV
Come on Paul. A bunch of the hot wheels broncos have torque thrusts on them so y know u have seen them:p
Hah! Yeah, that's true. So does the Baja slot car in my set, now that you mention it.
Guess I can get out my magnifying glass and check it out.;D
Scoop
Bronco Old Fart
Cuchara, CO
It's been done!
Crush
Greenbottom, WV
HEY SCOOP, more info on the roadster doors please. been lookiin at doing inserts and thought about doing just what you did
56f100bbw
56f100bbw
Torque thrust
They are going on my 76 bronco factory ford disc brakes ,,scoop those look nice I will have to show them to my machinist guy , Dirtdonk thanks for your input , I swap out wheels just a different look
I wonder if the ones on the red Bronco were already 5.5 bolt circle? Or were they all the smaller patterns, so they must have been modified too?
Clean job if so.
