Old school engine oil
DonH
WA State 30 miles from the beach
My 67 project is progressing to the point to where I need to install fluids. Oil products seem to have changed from what I am used to. Looking around I could not find 15-40 motor oil. Every thing is synthetic.
My completely rebuilt 289 flat tappet cam, I am sure, was not considered in todays engine oil. Modern engines have had roller cams for years and motor oils are being designed around them . The additives are different for these engines. The only 15-40 oil I found was designed for a diesel engine. I remember the letters on the on the bottle meant something and I do not know what they mean. One pare of letters meant there was an additive for flat tappet cams.
What oil is the group using for a new engine start up?
armynavy17
If I remember correctly, I used castrol GTX and a start-up additive. Their GTX line isn't synthetic. I also found cheap motorcraft oil at Walmart to be conventional. My builder recommended 10w-40 for winter and 10w-30 for summer.
The EPA has been trying to kill our engines for years. first they took the lead out, then thinned our gas with alcohol and now taking the zinc out of the oil.
sooner or later we will be pushing our Broncos.
BUCKWILD
Butte county
The 15-40 diesel engine oil will work also, it is just higher detergent and i have run it for years. ANy 10-30 or 10-40 is what is recomended, IF it us a rebuild run conventional iol for about 5000 miles the you can use synthetic
spap
Va olive racing its has higher zinc
higher than what I don’t know, use in my boat Motor for years
DonH
DonH
DonH
DonH
This Bronco may never another 5000 miles. And I am leaning to the Diesel 15-40 oil.
Timmy390
Conway, AR
Lots of break in additives out there with ZDDP/Zink
Last flat tappet I broke in was a 390FE.....I used a quart of Crane Cam break in (it was a Crane Cam) and 30W non detergent per the builders advice. All went well
Since then I've bee running Rotella t4 15w40 1200 ppm of zinc. I also run it in my 351W roller cam Bronco and my 1.3L Samurai.....
Tim
tirewater
San Francisco Bay Area
If you're breaking in a flat tappet camshaft, use the break in procedure and fluids that camshaft manufacturer recommends. Comp cams has a guide here: https://www.compcams.com/pub/media/wysiwyg/CompCams/FlatTappetCamTechBulletin.pdf
Last oil change I used Valvoline VR1 Racing Oil - 10w-30. Has 1400ppm Zinc, and 1300ppm Phosphorous. It's not terribly expensive and not completely a pain in the bottom to get.
