Over heating
Skytrooper15
Tuscaloosa,Al
If you have changed the thermostat and the radiator cap you need to remove the radiator and have it flow tested by a good shop.That will tell you if you have any tube blockage in the radiator making it run hot.Like a couple above said it also wouldn't hurt to do a compression test also.
What does the plugs look like? If i was a gambling man i would bet on a bad head gasket. Boiling over without running hot is usually a pressure leak. If you short the the heat sensor wire to the engine block with the key on does the heat guage go full hot?
J
jacob1963
Gonna pull plugs look.
I miss spoke early post, it’s definitely over heating. Crazy though it can idle for 20+ mins and not over heat. I take it around the block and it over heats. There is some noise coming from the water pump not sure if bearings maybe going bad. I have changed thermostat already. I will take radiator out and flush it really well today. Then do a compression test if I can get my hands on the tools today. The head gasket was changed 2-3 years ago, but guess it could of gone bad already....
Justafordguy
Did this problem start all of a sudden of slowly get worse over time? Unlikely that a radiator would get plugged up all of a sudden. The water pump impeller falling off or head gasket blowing would be more of an all of a sudden thing.
Can you see water flowing through the radiator with the cap off while it's idling ?
J
jacob1963
It happened one afternoon on a 30-40 min commute. Got home let it cool of and my coolant was low. Added more coolant, drove it the next day to work which take 7-10 mins no problems no steam, no over heating nothing, but on my way home it overheated still only a 7-10 min drive. Prior to this no other issues.
Skytrooper15
Tuscaloosa,Al
Listen very carefully when DirtDonk tells you to check something because he takes these old trucks we love so much and takes them apart and puts them back together.Everyone that has posted are doing their very best to help out and it is hard to put a finger on what is happening to your Bronco without seeing it in person.Like said above me if the water pump is wearing out maybe a bad bearing,you should be able to take the belt off going to it and maybe feel by moving the fan blade back and forth and if there is any play in it replace it.Then again if running hot is on a warmer day than when it is cooler and it doesn't it could be a bearing with no movement and is just getting tight.If it were me and I had a noisy water pump then I would go a head and replace it even if it's not the problem it might leave you on the side of the road one day.There are some very knowledgeable members trying to help and like I said it is hard to diagnose a mechanical problem without putting your hands on it.When you do fix the problem please let us know because it helps everyone to hear what the problem was.Hope you get back on the road again soon.
jw0747
San Antonio, TX
Take it to a reputable radiator shop and let the experts pressure test your cooling system. They have experience with cooling systems and overheating issues that are tough to diagnose on a discussion forum. Pressure testing can point to where you are losing coolant.
That's a good start for checking for any combustion issues. Easy enough to do.
But check your timing too, because if it has changed you can see temperature changes as well. I don't want to send you on a wild goose chase, but timing is so easy to check that it won't waste much time if it turns out to be a dead end.
Not at all. At idle there is virtually no load on it and many engines can take their sweet time with warming up, letting heat issues rear their ugly heads, and many other things.
And at idle, even a bad ignition advance issue won't show up because the base timing may be perfect.
You can speed up the warming process by revving the engine up, but it's still not mimicking normal driving conditions under load.
If this is from dead cold, then that would be odd when compared to just idling it. But if it's happening quickly, but after it's been idling for 20 minutes prior, then that can be normal too.
Usually takes more than just a block or two for trouble to show up, but the pre-idling has given it some little bit of a head start.
Doesn't really matter. Any noise at all from a water pump itself is indicating a problem deserving of a new pump.
Whether it's the bearing (99% of pump noises) or a failing/flailing impeller (rare, but happens) you need to replace the pump. The only exception is if it's the belt and/or pulley. But you should be able to tell the difference with a stethoscope. Or the driveway version of one, which is your long screwdriver touching the pump and the handle "in your ear" so to speak.
Long is good here, because it keeps your face and hands away from the fan.
So whether you end up doing anything with the head gasket or not, if the pump is making noise, it's time to change it out to a new one.
That used to be a sure sign you could ignore the thermostat from now on. Unfortunately we didn't get the chance to tell you (it kind of skipped my mind while we were on about the head gaskets and stuff) that new parts are crap. That's all you can say about them.
While thermostats might be well down on the list of bad parts we're getting, there have been several stories of defective t-stats right out of the box. Which is why many of us now test parts before installing them. Just like testing an old one to see if it still works, you're verifying the new one does before wasting your time, effort, sealer and maybe even anti-freeze again.
Definitely do what was already mentioned though, and test the upper hose by hand when the gauge gets near the thermostat's rating, wait for the upper hose to get hot all of a sudden. If it doesn't, then you're not out of the woods on the new stat yet.
If it does work, then that's one item down off the list.
And speaking of anti-freeze, at this point I would be using water only for the time being. Until you are sure it's all dealt with, no sense in making a mess of draining and wasting good coolant if you don't have to.
If you're good at catching and re-using, that's one thing. But I just prefer water only for less hassle.
Did you do that already? Or just drain and re-fill?
Bummer! Yeah, they can go bad. Goes back to the crappy parts syndrome at least in part. But other things can come into play too.
Did you have the head and block machined smooth for the install? Or was it just a new gasket.
Oh, and speaking of fans...
Make a habit (you have to train yourself if you have not already from experience) to stay out of the line of fire of old cooling fans. Whether factory or aftermarket, you can really get smacked good (or even killed) if a blade lets go while the engine is running.
Sure, it's a very rare occurrence. And with so many new vehicles running electric fans with full shrouds, I bet even pro mechanics don't think about it anymore.
But ask any old-school mechanic if they stand along the line of a spinning fan and I bet most say no way! They may even know someone that has been effected.
It's mostly old fans of course, but what are we running? Old fans...
Just as an additional incentive, a new Bronco-friend picked up a pretty built up '66 two or three years ago and just a few days after he got it home and started driving it, the fan lost a blade. Took out the power steering pump, left a few other marks and knocked a nice clean sliced hole in the newly painted hood.
Sure glad nobody was hanging out under the hood when that happened!
Just a quick PSA since it sounds like you're spending a lot of "quality time" under your Broncos's hood.;)%)
blubuckaroo
Grease Monkey
Ridgefield WA
jacob1963,
I think you should just pull the head off. It's really easy on a six, and since you're the owner, you've been doing the valve adjustments anyway. Pulling the head tells a lot. You just need to look at the piston tops to see the difference. Also, you'd have the opportunity to verify that you have hardened valves/seats.
J
jacob1963
So I have changed the thermostat, flushed the system completely, installed new water pump and change oil and filter just to see what my oil looked liked ( no coolant noted). Anyway burp the system of all air, test drove for 20mins no problems ran about 190. Stopped the engine and had over flow of coolant let it cool off checked fluid level and it was still good. Test drove again for 20 or more mins, stayed at 190, maybe 200 when at stop sign and back down when moving. Thinking the initial overflow was from over fill. Anyway think the problem is solved.
Thanks everyone for all the input!!! I really appreciate it!!!
71massbronco
So was it the water pump? What did the impeller look like and how did it operate? Enquiring minds want to know!
J
jacob1963
Impeller look ok, bearings seemed a little loose.
Anyway ran well for a day started over heating again today, will test the radiator for exhaust gases tomorrow and go from there. I see a head gasket or complete rebuild while I’m at it in my near future.
Thanks again everyone for the help it was greatly appreciated.
Skytrooper15
Tuscaloosa,Al
I don't think just a flushing will clean a partially restricted radiator.I watched many times that in a radiator shop they removed the top or side tank and poured muratic acid into the tubes and then rodded the tubes out to unstop it.You need to at least take the radiator to a good radiator shop and have it flow tested.They usually don't charge much to just check it if you walk in with it and the shop doesn't have to remove it.Again like several other members have said that if a water pump has a noisy bearing it is time to replace it because when the bearing warms up it is subject to slow down pumping or bind on the shaft.Don't wait until it comes all to pieces because it might come apart and damage your radiator.By the way what is the number of blades on your fan?Also does it have a shroud?
blubuckaroo
Grease Monkey
Ridgefield WA
jacob1963,
Is it actually overheating, or is it just pushing the coolant out?
The difference is, overheating is caused by poor cooling. Coolant can be forced out without being overheated if there is a cracked head, cylinder wall, or leaky head gasket. If it's not getting up to 212 degrees, there's no way it's boiling.
These sixes came from the factory with steel head gaskets that would eventually fail. Replacements are made of a composition that doesn't rust. They last longer. However the new gaskets are thicker and require head milling to keep your compression ratio where it needs to be. Milling a head isn't a bad idea anyway, and can be done easily without disassembling the valves from the head.
pipeline010
you said you recently had a new head gasket installed on the engine?
...is it possible the gasket was put on backwards? It does fit that way, but the open hole ends (left in the pic) needs to be in the rear to circulate the fluid properly. If somebody put it on the other way it would look fine but the engine would overheat easily.
just an annoying thought...sorry.
Justafordguy
I don't know if the 170 I6 head gasket will go both ways.
