jmhend
- Dec 25, 2007
- 2,741
Ok, I have hit a road block in switching over to a Saginaw PS pump. I am running a Mustang 5.0 and front dress. I have a new to me Tom's Saginaw pump (it came with a v-belt pulley). I pulled that off and tried to install the mustang pulley and no go... the Mustang shaft is smaller. the Saginaw pump has a .750 shaft diameter.
This bronco predominantly sees about 500 miles per year on the road with 4-5 off-road trips per year. 37" tires are not fun turning when the pump can't keep up at idle on the rocks so.... I am hoping an under drive pulley will help while I plan for a ram
So another member JohnJohn mentioned that WH had an under drive (smaller than the 5.8' factory one). I called WH yesterday and they no longer sell the smaller pulley. .
Then I called Toms', they do not sell a Serp pulley at all.
BC sells a 5.8" pulley
I called PSC and they have a 5" pulley with a .750 shaft but it is for a LS 5.0 (link:https://www.pscmotorsports.com/moto...nents/pulleys/n-pump-pulleys/psc-pp3508l.html)
Many thanks for suggestions, options and solutions....
BTW... for reference in the future for others here are also some viable options for a v-belt and 5.8" pulley from several years ago.
https://classicbroncos.com/forums/showthread.php?t=93184&highlight=saginaw+pulley+part
Jason
Jason
