How necessary or useful is overdrive?
allen
When i first started building up my bronco, overdrive was really important for me for some reason. Now not so much i think. i need to replace my transmission, i have a t-5 that at the time i loved, but the overdrive was horribly too tall, something like .63:1. the bronco has been off the road for a while. so now im thinking, do i really need OD if im not going to be cruising the highways at 85mph? Is it better to just have it anyway? I was hoping to get the ax-15, but there are so many options to consider. What other manuals are good these days? If i go with an auto, what are the good options, all i am familiar with is the c4
thanks
allen
Yeller
Rogers County Oklahoma
AX15 and 4R70 are the most common swaps. The drivability of both is better than virtually everything ever offered in a bronco. If I was building a bronco and wanted a manual, I wouldn't think twice about an AX15. If I wanted an auto I would happily do a 4R70 unless I just happened to have a C4 connected to a motor that I wanted to run, even then it would be iffy, the 4R70 has a lot of improvements besides OD, like a lower 1st gear.
Timmy390
Conway, AR
What size tires and what gears are you running?
T5 ratios by year
1983-84 2.95 1.94 1.34 1.00 0.73 2.76
1985-89 3.35 1.93 1.29 1.00 0.68 3.15
1990-05 3.35 1.93 1.26 1.00 0.68 3.15
2005-10 3.75 2.19 1.41 1.00 0.72 3.31
M5ODR2
3.90 2.25 1.49 1.00 0.80 3.39
Love my M5ODR2. 33's and 4.11's OD is very usable. Can cruse up hills and head wind does not cause any issues.
Tim
I'll point out that overdrive is useless if not paired with the correct axle ratio and tire size for the engine.
It is about gear spacing and gear spread. A low enough low gear that you get away briskly without letting all the magic smoke out of the clutch disk. A high enough high gear that you can cruise comfortable. But not so high that you are lugging the engine below where it is efficient at. But that low gear can't be too low either or you get frustrated at the first shift coming a few feet after you are moving. So that pretty much defines the upper and lower overall ratios to make for happy driving. But what is in the middle also matters. You need good spacing, where it feels right to shift puts you into the next gear at a usable engine speed. This is where those really wide ratio transmission (NP435, ZF) are not that great on the street. Rev it out, shift, lug it into the next gear. The more car like close ratio transmission (NV3550, AX15, M5R2) often have 2 or even 3 different gears you could be at for a given speed, all depending on if you are just cruising, trying to gather some speed, or flat out packing the mail.
Digger556
Overdrive is very useful, even for 55-65 mph cruising. Not only does it improve your mileage, it reduces wear on the engine and reduces noise by lowing the operating rpm. The most important thing is matching your axle gears to your engine and OD ratio. Overdrive will allow you to run deep (numerically higher) axle gears, which is great for towing, crawling, and accelerating.
ZF5 wide-ratio version is a great option for torquey engines like 351s or diesels. Higher revving engines like 289s and 302s would benefit from a closer ratio transmission.
SteveL
Huge chevy guy
Hawthorne ca
How are you going to use the bronco? If not a daily driver or on the highway alot is it worth the extra labor and expense to go od. I guess this answer is motor if you're going with an automatic. With going rates you could probably get a running c-4 in the bronco for about 1k. If you want an automatic with od probably 3k.
allen
allen
I have a ‘92 lx 5.0 with 4.11 and 33’s. 3.5” susp lift and 3” body lift (want to remove it as thats how it came when I got it). I’ll probably drop to a 1” body lift for clearances. So with a total of 4.5 “ lift 33’s may look a bit small (they look tiny now). If i stay with 33’s, i can stay with the 4.11 and figure out tfans options from there. If i go up to 35’s then a bunch needs to change. Or drop susp to 2.5…so many choices :)
cldonley
Robinson, TX
Always get an education from Mr. Bowsher. My plan is AX15 and 4.11s with 35s. Plan to run that set up around a while with just 2 wheel drive to see how it feels before comitting to it in the D44. Just takes time and money... Shoulda said I'm running a 351W.
Digger556
That will work. I ran 4.56s and 37s with a 351W. Even at altitude it would pull the grades here in CO in OD.
Why? reading the OP's post again that doesn't look like what he is after.
Sounds like the desire is a T5 but a more usable overdrive ratio. The ZF is more like the original 3-speed with an overdrive and a granny gear.
There was also the comment about what good automatics are out there for swapping in. The 4R70W has been a great choice for decades now.
But if I were starting with a clean slate, look at a 6R80. They are now adaptable to the small block. stand alone controllers. Low 1st gear and close ratio 2-6 gears. Top OD is a little tall, but you can have limited usage of it and still run the lower OD mostly (I had a rental ram truck with the 8-speed that did this. Ran highway in 7th and only used 8th when things were just right). The transmissions are also known for taking some serious power even in stock form. A co-worker got a Coyote F150 and put the biggest blower on it he could get, then went further with E85. Ran it for years and upwards of 100k of lots of abuse. He blew a rear end, hurt the motor, but the transmission was always good.
