abrush
Driving my 70 Bronco with a 289 engine home last night I noticed my guage was reading much higher than normal. I tipped 230 degrees when I pulled her in the garage and steam was coming out of the overflow. After a little more research I noticed that it was very low on coolant but had no noticeable leaks. I know this is a bad sign and a lot of the time is a blown headgasket but I just installed brand new headgaskets a few months back so I doubt this is the case. I had been driving this Bronco quite a bit since and never had a problem until now. It had never topped 190 degrees on the guage before. I pulled one of my breathers on the rocker cover and did see what appeared to be white snot all over in the breather. So my question is how do you diagnose a cracked head or block? I have a spare 289 laying around that has some good parts on it but I'm not sure how to tell if either one of my heads is cracked/warped or even the block. Any suggestions?
