johnmlebel
- Jun 17, 2007
- 1,366
I am putting in a painless harness in my truck using HEI and an electric pump out of all the extra wires under the hood is there one i can run the pump up there off of, thanks.
the only power source to the duraspark wires come from the coil + wire (#920). Check out the diagram on page 69 of the manual. That diagram shows the power source. What you can't see in the picture is that the wires coming from the starter solenoid are only hot with the key in the start position. i know none of this is relevant to you fuel pump wiring, but it may help you understand what unused wires you have.
EricOo1, are you a painless rep? If you are that is very good customer service! Very quick response and you truely care about your product;D
With help from lots of forum members here I designed the new bronco harness.
I swing by this site about 4 or 5 times a day, more so during the week and maybe once or twice on the weekend. I just type "Painless" in the search field. I just try to help answers to questions because I've got a lot of pride in this harness. I worked really hard on it and I like seeing it put to use.
With it costing a considerable amount more than other harnesses I want people to really fell like they are getting their moneys worth. I try to get a fast and reliable answer to those who are installing or considering a purchase, most of the time forum members beat me to it.
I tried to wire my fuel pump to the afformentioned 5-8 accessory wires. I could not hear the fuel pump kicking on. Could it be that these circuts are not getting any power? A ground issue perhaps. The fuel pump kicks on when I put the wire directly on the plus side of the battery. Thanks.
