Out of curiosity, is this schematic a “generalized” diagram or is it specific to Painless? I ask because I have an AAW harness (still in the box) and am looking for every cheat sheet I can find..
I'd use ohm meter vs voltage to check for good grounds. Disco battery, run a small wire from battery ground cable (not connected to battery) to near backside of instrument cluster, then use an ohmeter from the batt gnd wire to back of instrument cluster to check for resistance.
I would do same for all your ground straps to battery cable, should be close to zero resistance.
