Painless harness routing
reamesc
Columbus, GA
Ok I've read the manual but I'm still unsure on how to route the new harness. Am I supposed to use the hole in the passenger side or behind the engine? Is it modified if I run it through the passenger hole? Also are there clips behind the dash to hold the harness up? How and where do I transition from the engine compartment to the frame for my rear harness? Does it go down the inner fender well?
SHX669
The harness has lots of zip ties holding it together . Find the wires going out from the passenger side of firewall - separate those and rezip the rest of the harness . Then go to wires going out above the gas pedal , isolate those and rezip rest of harness . Then go to the wire going out of firewall above the e brake - run all of the SEPERATE little bundles out the firewall. For me the Painless instructions were wonderful. The hardest part was talking my self into cutting the zipties. LOL
Ok - to clarify go out the firewall in 3 locations - passenger for starter relay and power in , above gas pedal for temp gauge , oil pressure , {choke can go here or on pass side - up to you }distributor wiring ,tach wiring. Driver side is the headlights , washer pump . etc - the instructions are pretty clear. Yes the stuff going to the back runs out the driver side firewall down the cowl/fender area , then to the inside of the frame or on top of depending if you have a body lift . The wire crossing from the driver side to passenger side go over the gas tank.
SHX
R
reamesc
Columbus, GA
That clears most of it up thanks, how do I secure it to the frame when routing to the rear? Just zip ties around the entire section?
I've used the rubber-insulated steel line clamps before and it has always come out looking way more professional than you would expect using that old technology.
But there are also a lot of coolio clamps out there today that are much more modern, whether out of billet aluminum, stainless steel, or plastic.
Or you could zip tie them to brake and fuel lines, or to something you've put where you want. Up to you completely.
I was actually quite surprised at how decent the old auto parts store bought insulated clamps looked. I'd always kind of steered away from them in the past. But then one time we needed something quick and sturdy, and went down that road. Worked great!
