- Nov 11, 2007
- 7,842
Thought I'd throw up a post on this topic for those going Ididit steering column route to put the info in one spot.
My issue is the ididit column came with the flat connector no the 4x4 square connector so I have to splice. I went with this plug to make it easier:
https://www.amazon.com/gp/product/B07JC6X41W/ref=ppx_yo_dt_b_asin_title_o07_s00?ie=UTF8&psc=1
If you have a painless wire harness, or even stock harness with square plug from body harness, here is how you hook them up:
Go to Wild Horses website and open the tilt steering column webpage.
Upper left side is a link to PDF document for wire harnesses.
In that document you will see a painless wiring section, and a GM/Flaming river column section.
Apparently Ididit uses flaming river/GM wiring.
So all you need to do is match the painless colors to the GM colors and Ididit column will work.
Verified through techs at Painless/Ididit, WH.
One note, you must ensure the steering column body grounds to EB body/negative side of battery. Should be no problem with an aluminum or chrome like mine, but a powder coated or painted may not ground through the mounting bracket to the body to the battery. If you don't have a ground the horn and turn signals won't work.
While you could just crimp and heat shrink, I crimped, soldered and heat shrunk then wrapped with loom covering. Sort of looks OEM.
