What I would do is leave the gun pressure set to 60 psi. disconnect the air hose and pull the trigger back all the way and adjust the material flow knob so it backs the trigger out all the way to gain maximium flow. while pulling the trigger back, screw the knob in until you feel the trigger move forward. now screw the adjustment knob another 2 turns in, this puts material flow in some kind of adjustment level. Now hook up the gun and add primer and adjust the fan width spray knob wide open. and spray a swath of primer. While spraying this adjust the fan with knob until you see the width narrowing down about 20 %. I do this while spraying on a large piece of cardboard. so I can rough set the gun. Now try spraying your part and adjust the distance from the part to the gun to get the best lay down. Now if that doesn't get the results you want then try adjusting the air pressure. and lastly then you may need to adjust the amount of reducer from the recomended mix. Now from this gun set point you have meaningful adjustment room and adjustments will be small and noticeable.
