I have a ton of experience painting at home in the garage. My coworker and I painted probably at least 100 cars for a used car lot in my garage a few winters ago when it was slow at work. This is how we got the cleanest jobs.... We would do bodywork to as many cars we had on hand and prep them all for paint, then empty the garage. We would then blow out the garage, every nook and cranie, every corner, the walls, ceiling, and under everything. We probably spent 20-30 minutes blowing it out. We would then wet down the floor and blow off the 2 cars one last time while they were still outside. Let the shop settle down with the fan on for 5-10 minutes before pulling in 2 cars. We found we got cleaner jobs with the shop closed up and the fan on. My fan is a whole house fan built into the wall as seen in the picture below. I would tack off between each coat of base and prior to clear. I also found it best to hang up hoods so dirt wouldn't settle on flat surfaces. We did get dirt in the paint but I was very surprised how little we got for a garage spray.
