Awesome. It sounds like what I need. I have never sprayed paint or primer hence all the questions. What gun do you recommend for the epoxy. Is there a reliable gun for both the primer and paint or do I need separate units? I'm looking at doing the whole thing myself as paint jobs are pretty high. What paint brand do you suggest (best bang for the buck). This is going on a trail rig, so it doesn't have to be great but I would still like it to look decent.
You can get by with one gun for both primer and paint if you clean it out good. If I were you I would get a cheap gun from Lowes or Home Depot for the primer. They tend to have a larger tip like 1.4 or 1.5 .
For your base and clear I would get a better gun with a 1.3 tip. If you spray base or clear with a large tip gun it will not lay out as good and tend to have more orange peel.
What gun to get?? Ask 10 painters and you will get 7 different answers. Most painters tend to like SATA's. I have about 8 or so SATA's but they are $$$ but also excellent guns. I also have a few Geo's made by Walcom which are good guns. I also have an Acuspray but it doesn't spray clear very well, good base gun. I also have a Devilbis GTI that I have used as my sealer gun with a 1.3 for the last 2 years. I bought it for use as a clear gun but I like my SATA RP for clear better. The GTI would work great for your needs and as a first time user gun.
For the paint.... PPG or Dupont are decent paint lines but it's going to be a trail rig. You could get a good covering base coat (like Spies) and use a cheaper clear. I've used most cheap low grade clears from Keystone to U-Pol. For the older cars I paint at work along with the used car dealer I do side work for I use the U-Pol. It might fade/die back a bit in a few years but a buff will bring the shine back.
I buy all my spray guns from spraygundepot.com which is a site owned by tcp who also sells paint and paint materials online. Most of the time they are cheaper than my local jobber and I save the sales tax
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
