This morning my drivers-side door latch didn't work and my door was stuck shut. Both outer and inner latches would move freely without engagement. After crawling in and out the passenger side all day, I took it apart to see if I could determine what the problem was.
First off, let me say; taking the door panel off with the door closed is super annoying.
After banging my head, dropping my flashlight, getting my fingers covered in grease, and having a quiet fit in the heat; I found that the window track appeared to be loose and holding the outer latch mechanism in between states.
Also while digging around, I found some loose parts. See below:
After looking at them it would appear that one part is a genuine jb weld fix by the PO...
So the remaining question, what is the keyed washer for?
