Passed Inspection with Beadlocks
JohnJohn
Richmond
I just thought I woud let everyone know that I passed our VA safety inspection this morning with beadlocks. They are not ilegail in VA. ;D
sprdv1
REBEL
Nice!!!
Gonna be doing that myself here pretty soon..! wish me luck
JohnJohn
JohnJohn
Richmond
Thanks for the complement.
They know they are real. I bought the tires from them and they poped the first bead on for me a couple of months ago.
VA law is the wheel and tire must be properly mounted. Nothing preventing a beadlock.
Mountain Ram
Recovering Masshole
Abingdon, VA
Beadlocks and split wheels are legal in all 50 states... if they have a DOT stamp on them. That is up to the manufacturer to get them approved. If there is no stamp- you cannot run them on the road- same for tires.
I bought Bart beadlocks for my rock crawler 8-10 years ago. They were not supposed to be stamped as they were advertised as 'not for street use'. Bart sent the wrong wheels- non-beadlocked DOT approved wheels. I returned them, they cut the lip off and welded on a beadlock ring. The wheel still carried the original DOT stamp.
I was later pulled over by a VA state trooper that knew about beadlocks and actually checked the wheel for the stamp. All was well, but I did get a tigket for dark window tint.
TD
stupidboy
My wifes porn star.
Morrisdale Pa.
I know that spit rims are no longer legal, but are bead locks 2 piece? meaning does the bead lock need to be in place for the tire to be held on? I have almost no experience with them.
Scoop
Bronco Old Fart
Cuchara, CO
Yes, the ring holds the tire to the outside of the wheel on one side.
78Scronco
There are so many fake beadlocks out there nowadays that I would think it would be hard for them to pick them out without serious inspection.
That is what I was thinking as well.
If you want to get into DOT regs, how many of you putting 1-tons on the rig are also putting the clearance lights on? Even the Raptor got clearance lights (in the grill) due to width. DOT regs are needed for selling the vehicle and for using it commercially. Private use, damn near anything goes.
half cab
Guru Bronco
Who would have thought it,but your right.
Zillacon
Hackin Away!
This Beadlock issue has been beat to death since the early 2000's. Some of the retailers even have had rewards for anyone showing proof with a written law that they are illegal and to my knowledge none of the rewards have been claimed to date.
JohnJohn
JohnJohn
Richmond
Actually someone on this board showed me a law in Utah clearly stating they were illegal. But I can drive my Bronco with VA tags in Utah. :)
Wheel spacers were also out in Utah.
av8rds
MAhole!
2300 mi East of Moab
you dont have the chapter and section do you? I'd love to read it. Not trying to bust your balls but I'd really like to see it.
JohnJohn
JohnJohn
Richmond
LATEST STATE OF UTAH SAFTEY MANUAL page 20 F.WHEELS 1Check wheels for any damage and proper mounting Reject vehicle when a) Has 25% or more of the wheel bolts, nuts, studs, or lugs loose, missing or damaged per wheel. b) Wheels are bent, cracked, re-welded or have elongated bolt holes. c) Spacers are used to increase the wheel track width.
NOTE: Custom wheel adapters are not spacers. Also, "BEAD LOCKS" on Rims are illegal and will be a reject.
joshd1971bronco
Oklahoma City, OK
Yeah, you can do a google search on 'are beadlocks illegal' and read volumes of things. DOT approved does not necessarily mean 'street legal'. It's all bureaucratic red tape lanuage. Hard to decipher.
One thing to keep in mind if you DO have beadlocks and drive them on the street at normal / highway speeds, please check the bead lock rings regularly to make sure they are tight. Due to the way the bead lock holds the tire on the wheel, if the ring fails or comes off at highway speeds (like 60 or 70mph) it would be catastrophic and very dangerous.
Zillacon
Hackin Away!
I think he meant the actual law. That is nothing more than the steps required for their Biannual safety inspections. I'd like to see the actual law.
Utah laws do not say they are illegal, though they do grant the UHP the right to enforce the motor vehicle code. So you can get a ticket, but it wouldn't be much of a case... then again they can ticket you for having a pink Bronco too... but at the end of the day they have to have a law to back it up with.
The Utah inspection also goes over mirrors, brake pad depth, heater controls etc. Might get a ticket for that too.
Rockstomper has had a reward since 2002 on Pirate for anyone showing him an actual law stating Beadlocks are illegal in any 50 states. No one has come forward to date.
