- Mar 2, 2013
- 2,660
I took it for granted that the hood on my Bronco fit when I tore it down. I have finally got to the stage of putting everything back together and found that my passenger cold air intake hits the hood. I left the air intake off when I installed the fender and the hood and then had to go back and install it when I realized I forgot it.
I have an aftermarket hood that came with my Bronco. It looks like the WildHorses Classic hood scoop model. It has extra bracing built into it on the bottom side and that is what is hitting the air intake.
I am thinking about cutting the top of the air intake down at the point where it has a lip on the fender side. Making a straight cut all the way around (basically a 1 inch thick square) and then inset that piece back into the hole and epoxy it back into place, I may need a filler piece on the tapered side.
Has anyone had to modify one to fit, if so do you have any pics? I am open to any suggestions you might have as well.
Thanks in advance!
Thanks in advance!
