Petronix Coil clearance issues with Distributor TFI module plug...
jesus888
Atlanta, GA
So one more thing before I go to sleep...
As we were trying to get the motor cranked for the first time today, we ran into an issue with clearance between the Petronix Flamethrower coil and our TFI module plug on the distributor...
We had to spin the distributor to get timing adjusted, and after realizing the clearance issue, we just unbolted the coil and moved it temporarily to a different position so we could spin the distributor a little more.
We had it mounted just like on the BCBroncos site (like here).
Has anyone had this issue? and what did you do to alleviate the issue?
We tried to mount the coil differently on the BC mount, however it was putting it about 1/8" from the fan belt which is a little too close for comfort :(
Thanks in advance!
chuck
Ingram, Texas
If you feel that the coil is too close to the belt move the dist. one tooth. P.S. it sounds a little close to me but if the timing is goodthe 1/8" will not hurt anything but moving the dist. 1 tooth will give you more adjustment.
broncnaz
You need to reset the dist back a tooth or two. that will gain you the clearance you need.
jesus888
jesus888
Atlanta, GA
We are gonna give this a try... we kinda tried resetting the distributor on Monday but kept running into issues... by the time we rotated the distributor enough to start hearing the motor getting close to firing, we started hitting the coil again.
We have a buddy that's much more versed in 302 EFI that's gonna stop by sometime this week and hopefully get it fired so we can set the timing and break in the cam. Fingers crossed :)
When you're moving a distributor over a tooth or so on the drive gear, you have to also move the oil pump driveshaft to match. You can make up a long extension and socket to fit, or, if you're really brave, you can rotate the engine by hand till the gears mesh properly and the distributor drops in.,
If you go the socket route, just be sure that it's taped on or at least VERY tight fit on the extension. You don't want to have to fish out a socket that dropped off the wrench and into the well.
ak68
I would move the coil rather than jumping the distributor a tooth or two. The injector sequence is timed so by moving a tooth or two on the distributor you will have your injectors firing out of time. Take a look under the dont's on this SBFtech page http://sbftech.com/index.php/topic,119.0.html
chuck
Ingram, Texas
That artical is talking about not moving the plug wires on the cap because the TFI relates to number 1 for firing the injectors. If you move the distributor the TFI and #1 move together so you can move it as much as you want.
ak68
That would be correct since jumping a tooth or 2 moves the entire distributor. If you have to rotate the body excessively to get the timing right does that put your injectors out of sequence? The stator triggers the injector pulse and it would not move in relation to the plug wires when the body is rotated for timing.
jesus888
jesus888
Atlanta, GA
UPDATE: We removed the coil, set the timing, and THEN moved it back a tooth like you guys said and remounted to coil...
