Pick and pull find
Pnshr71
Central Texas
I was wandering through the local pick-n-pull and found a 97 mountaineer, 5.0, with complete drive train from the engine to the transfer case with about 150,000 miles on it. I would, of course have to pull everything myself.
I have the original 1971 302, trans and transfer case.
Ive been wanting to upgrade the drive train, so 2 questions:
1) is this a good snag
2) i have limited mechanic skills but can generally figure things out with a litt reasearch, is swapping drive trains way above my pay grade?
Thanks.
badmuttstang
redneck grease monkey
If your wanting the efi as well your going to be better off buy a whole explorer or mountaineer. Shouldn't be that hard to find one and that way you have everything you need right there and can sell off what you don't to recoup some of your costs. As for mechanical skills you will need to have some and I can't speak for your skills so I'm not going to make any assumptions but you should be able to do it with some help from everyone on here.
Bronco73
Cape Coral, FL
If you want an OD auto and EFI then this would be the way to go. It would the be the cheapest way to get both and IMO the best choices. Just make sure you grab the wiring for both the engine and trans, computer. There's a post on here that goes over what you need from the explorer for the EFI and trans to work in your EB.
ScanmanSteven
Might not be bad that someone got it. It probably had "P" heads which stands for pita if you use headers. Switching mine over as I type. Fine the post on the swap which will help next time you find one.
