Pics with wild horses black halo LED headlights
White Knight
Anyone have the black halo LED headlamps and if so can you post a pic?
All I could find is a pic with the lights on.
I know I've got some better shots here somewhere. Let you know if I find them.
In the meantime that's "Gramps" which is the shop's '76 test vehicle.
You might find references here and there on the website, but I don't know any particular pages it might be found on.
Justafordguy
Mine aren't Wild Horses brand but they look just like em.
White Knight
White Knight
WH Halo LED Headlamps
ANy feedback on these .... did you modify the harness? Are they brighter or more for that resto mod look?
War Eagle! ;D
As for mounting the lamps themselves and running them as just headlights, there is no modification needed for the wiring harness.
However, I'm under the impression that that all of these have separate wires for the halo which lets you choose your function. Either as running lights, as turn signals, or both.
Since there is no interface harness supplied (that I'm aware of anyway) then the halo function is not plug-n-play, but would need some minor modification to that circuit.
What did you have to do to get yours working justafordguy? And are you running them as turn signals or running lamps? Or at all?
Justafordguy
The ones I have have a standard plug for the headlight function, plugs in with no modifications at all. The day time running light (white halo) and turn signal (orange halo) have separate wires. I spliced each one in to the correct wire at the factory turn signal harness. The white halo is on when the parking/running lights are on and the orange halo blinks with the blinker.
