jimschulz
I have a 5.0 thats getting ready to go into my EB. I had installed a new ford needle pilot bearing, but failed to realize it wouldnt work with my NV3550 trans. Simple enough, I went to remove it to install the correct bearing, but the puller just pulled the inner needle cage out. I have tried getting the outer portion to come out with no luck. I pounded the inner race back in and tried the grease method and it just wants to push the inner cage back out. Anybody have a suggection to get the outer portion to come loose????? I did try a little heat, but dont want to get too hot. The puller only has about a 1/32nd to grab the outer portion and its just chips off the edges......Ugh
